RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Aileron Mixing into Split Elevator (https://www.rcuniverse.com/forum/3d-flying-82/1094526-aileron-mixing-into-split-elevator.html)
sigflyer_us 08-27-2003 03:04 PM
Folks,
I would like to create a mix on my JR 8103 that enables the split elevator to move like ailerons. I want this to assist in controlling the rock in a harrier. Unfortunately, I'm unable to get this mix working because I already have ELEV mixed to AUX3 due to the split elevator.
Any ideas?
Thanks!
Ian.W 08-27-2003 04:23 PM
dont run JR but i'll give it ago
cant you just use a PMX to miw the elevator and Aux3???
sigflyer_us 08-27-2003 06:06 PM
Already tried that.
AIL and AUX1 are used for ailerons.
ELEV and AUX3 are used for split elevator.
To get split elevator to work I mixed ELEV -> AUX3 on mix5 so the trims work.
The difficulty is that to have this mix work you need:
AIL -> Aux3
Aux1 -> Elev
Due to the split elevator, I also have ELEV -> AUX3. So the programming ends up being recursive.
