RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Sbach 342 4S Engine (https://www.rcuniverse.com/forum/3d-flying-82/10946843-sbach-342-4s-engine.html)
flycatch 02-06-2012 01:44 PM
Sbach 342 4S Engine
I have a YS 140DZ that I intended to install in a DP 330 but the purchse of the airframe fell through. Now my attention has shifted to a NIB Sbach 342. I realize that most if not all 3D airframes are powered by gas engines due to the cost of glow fuel and reliability. Would this model YS engine be a practical choice to power this 3D machine.
ThumbSkull 02-06-2012 08:55 PM
RE: Sbach 342 4S Engine
No experience with that airframe but that 140DZ is better than most if not all of the 30cc gas engines especially when you consider it will probably be lighter.
BarracudaHockey 02-07-2012 05:49 AM
What size SBach? I"ve seen them from Umax up to 50%
Aerobatx 02-12-2012 09:56 PM
The Goldwimg 30 sized SBach 342, that Troy Built has on sale would work well with that powerplant, I think.
I have the 70 sized with a 60 inch ws, and the 30 sized has a 73 inch ws
nitro wing 02-17-2012 01:24 PM
stay under 13 pounds, use APC 18x6W or similar. You may have to extend the engine box on some models, depending on the mount you use. If you fine tune it, fuel consumption is reasonable. Threadlock and/or teflon tape the exhaust, it will shake loose. have fun.
Carpet 04-16-2012 11:04 AM
I know where there is a new in the box DP 330L setting it u are stile enterested in one
