RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Help! Need instructions on programming split elevator on Jr 89103 (https://www.rcuniverse.com/forum/3d-flying-82/1149522-help-need-instructions-programming-split-elevator-jr-89103-a.html)
earl williams 09-20-2003 08:29 AM
Lost my instructions on how to do this without servo reversing on 8103?
coony2787 09-20-2003 11:49 PM
RE: Help! Need instructions on programming split elevator on Jr 89103
it is simple just mix elevator to what ever channel you have the other elevator servo on make sure you use either mix 5 or 6 so the trim tab will work and if you have a switch that also works the opposing channel just go to another mix and mix the channel to itself and make the atv to -100% and the swtich will do nothing.
Chad
