RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Mufflar Lost (https://www.rcuniverse.com/forum/3d-flying-82/11602604-mufflar-lost.html)
ochsnm00 08-10-2014 11:52 AM
Mufflar Lost
I just lost the muffler off my new 50 cc RCG. Does anyone have a tip on how to keep a muffler from falling off. I was thinking of something like installing a short cable on it so it doesn't fall into the corn field never to be seen again.
rexbirk 08-14-2014 03:37 PM
I too had muffler issues until discovered the cure here on a forum. Here is the solution that works for me.
I do not use a gasket. I clean up both mating surfaces well and then clean them a final time with acetone. I then apply a very thin layer of Permatex Ultra Copper Sealer. I also put a dab on the threads of the bolts that attach the muffler (acts like a thread locker). Gently assemble the muffler to the engine and finger tighten the bolts evenly. I then torque it down tightly and let it sit for a day.
For me there is no more loose muffler and no leaks.
BarracudaHockey 08-19-2014 12:04 PM
That and Nord Lock lock washers
ochsnm00 08-20-2014 11:00 AM
I used the Permatex as suggested and so far it is holding. I had never heard of Ultra Copper.
MTK 08-20-2014 01:13 PM
Terrific stuff. McMaster Carr sells it for around 7$ a tube. It is high temperature silicone sealant with a twist... It resists gasoline exhaust great. I used NordLock washers several years ago along with the PUC, but have since moved away from NordLocks favoring PUC alone.... NL not needed. Try it...
