Plane for 91 4-stroke
I have the magnum 91 4stroke in a non-3d extra. It needs a new home: Here is what my ideal plane would be, let me know the plane that fits the bill.
Very 3d capable, fairly easy to hover Pattern like qualities, I.E I can actually fly around with it being precise, quick and go where you point it. I would prefer it be an ARF, but it can be a kit if its the perfect plane. Thanks |
RE: Plane for 91 4-stroke
i wood say the great planes 60 size u can do set up right it will do anything and presise its about the best of both worlds in and airplane for that price
I have had many 3D planes , the most pattern like qualities have to go to the you can do 3D 60 to 90 size. It hovers the best of any thing i have flown. I had a 91 satio with 16X4 APC, and try some 30% heli fuel.[sm=spinnyeyes.gif]
I couldn't think of a better plane than the UCD.
the new modeltech excite 90 looks good...
Are you kidding me?
The U Can't Do 3d a pattern like plane!!! You mught heve more luck with the H9 Funtana. There are a couple of videos of Zak flying his with a Saito 100 that will take your breath away. I think the site is www.3dbatix.com. |
I was thinking of the Funtana. It is a 3D plane designed by a pattern flier.
I did a kit review for R/C Report and it is very smooth. With any 3D plane, I would hesitate going too fast. the extra large control surfaces and counterbalances are asking for flutter. I had a Saito .72 in mine, but a friend has a Saito 100 with a 3-blade prop. His was fairly fast, but never gave a hint of flutter. Of course, he didn't do any power dives, either. We both used 4-40 hardware and tight servos. I used digitals. I also used the DuBro black clevices with the built-in clip on elevator & rudder. They fit fairly tight. I used bolt-through ball links on ailerons for minimum slop. |
Ed moorman brings up a good point. With a 3D plane that size, the control surfaces are going to be huge, and I don't have the money to buy digitals for it. Mabye a new engine and the udc 46, and just buy a high torque for the rudder? Any thoughts on that? Thanks
Alex Also, I was thinking funtana, can I use high torque non-digital servo's on those surfaces. They are absolutly huge. Would the play in the regular servo's be to much? Thanks |
ORIGINAL: snownskate69 Very 3d capable, fairly easy to hover Pattern like qualities, I.E I can actually fly around with it being precise, quick and go where you point it. I would prefer it be an ARF, but it can be a kit if its the perfect plane. Check out the 65" Extra 300LX. |
Maybe the UCD .46 and the motor you already have. I have flown one with a saito .91 on the front and you would have never known that it had such a large motor on it. However, the magnum weighs more than the saito does and produces less power.
If you go with that extreme flight extra posted above I would put a saito 1.00 or a Y.S. 1.10 on it for true all out 3D performance. I always say there is not use in buying a Jam up airplane if you dont have a Jam up motor on the front :) |
| All times are GMT -8. The time now is 08:38 AM. |
