OMP ailoron flutter
hi my name is john I have recently got my hands on a 2014 OMP EXTRA 300 and I love it but Im haveing a problem with flutter in the ailarons ????? I have tried new servos hitec 7950 TH s , sealing the gaps, tightening covering, checked all hindges and ball links. It seems to do it even at half throttal , so bad you can here it ...... what else can I try to fix this other wise wonderfull plaine ?????? S F Gs maybe??? Running DLE 61 Maybe vibrating to hard??? some one please HELP:( PS I know my spelling sucks
http://www.rcuniverse.com/forum/begi...s-flutter.html
but first make sure its flutter and not servo jitter... |
I once had an airplane that sounded like it was fluttering apart. upon a close inspection I found out the surfaces were not fluttering but where radiating the sound of a loosely mounted engine that was rattling through the fuselage. check everything don't focus on one perceived problem area.
Sometimes the control surfaces are very large and meant for 3D and the only way to avoid flutter is to fly slower .
My opinion is that if it really was flutter, you wouldn't have a airplane left to fly. Hard to believe that even after sealing the gaps you still have flutter. You may try use a counter balance on the control surface.---Smitty
| All times are GMT -8. The time now is 06:08 PM. |
