RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Diablotin Super pics added (https://www.rcuniverse.com/forum/3d-flying-82/116341-diablotin-super-pics-added.html)
3Dreaming 04-26-2002 02:15 AM
1 Attachment(s)
My Diablotin Super is ready to fly. I'm just waiting on weather (light winds). Ready to fly weight is 59.4 oz. with 935sq in wing area. I made a few changes for strenght, and controlability. It is set up as follows. HP.40 with Macs header, and mousse can muffler. Four Hitec hs225's, and a hs81 for throttle 720ma nimh and hitec super slim receiver. I started out with a Expert rf650 receiver, but the range check wasn't good, so I went with the heavier Hitec. The control is from a JR 8103. I have a Nolimit 3D that weighs 5.33lbs with a ST.51, and about 90 more sq in wing area. With the lighter weight the Diablotin should be a hoot to fly, and I hope to find out soon. Tom
3Dreaming 04-27-2002 01:31 AM
First flight
1 Attachment(s)
The weather was nice today, so I slipped out the door at work for a quick couple flights. The engine wasn't running quite right, but it still had plenty of power for vertical accelleration. It would hover at about 1/4 to 1/3 throttle, and it felt very stable. Loops were very tight, and if it was slowed down it would flip from upright to inverted or back with just a blip of the throttle. Rolls seemed a little slow, but I had it slowed down most of the time. I think climbing spins will work once I figure the amount of throws needed to keep it from flipping over. I think it is going to be a good airplane for close in 3D work. I hope to have some pictures soon. Tom
CHM 04-27-2002 04:07 AM
D Super
Thanks for the report. I'm using the same servos and battery in my Laser 3D, and a YS 63 for power. Should be ready in two weeks or so.
Chuck
3Dreaming 04-27-2002 12:26 PM
servos
In my Nolimit I used standard servos except for rudder, and I used a Hitec 605 there. The Nolimit is closer to the Laser 3D than the Diablotin Super. Tom
CHM 04-27-2002 01:41 PM
Oh...I have an HS-77 for the rudder.
How do you like the Nolimit?
I almost bought a Diablotin Super, but then I saw the thread on the Seduction and I picked up the YS and a Pizzaz for now. Someday I'd like a Seduction with the YS in it. The jury is still out on the Pizzaz. It's a heavy little airplane. Mine came in at 4 ounces over 5 pounds. I have an Irvine .53 on it. Great motor, by the way!
The Super looks good. And you're under 4 pounds! WOW! I think the Laser 3D is overbuilt in some areas and underbuilt in others. I hope to come in at 4.5 pounds with a few mods.
I'd really like the Diablotin XL for my ZDZ 40!
We've got wet snow and it's cold & windy today, so I'm heading to the shop to finish the Laser 3D fuselage.
gubbs3 04-27-2002 02:08 PM
antispad- We have rain here in Coon Rapids this morning. Yesterday I was home sick from school and it would have been a perfect day to go fly. Not a cloud in the sky and it was nearly dead calm.
CHM 04-27-2002 03:51 PM
No Flying Here!
1 Attachment(s)
We have snow 100 miles West of you!
3Dreaming 04-28-2002 12:24 AM
Nolimit 3D
The Nolimit is a nice airplane. I had the kit for almost nine months before I built it. When I ordered the kit the Laser 3D was not out yet. With the ST.51 it has planty of power, even at 5.33 lbs.. I think the Diblotin Super at 1.6 lbs less weight is going to be a better performer. The only thing is it may not hold up as well due to its light structure. Time will tell. Tom
modest-master 04-29-2002 04:03 PM
Diablotin
1 Attachment(s)
There is also Diablotin Super FG.
This model will take up to .90-1.2 4-stroke engine.
It has gel-coated fiberglass fuselage.
It's my favorit.
Wing area: 925 sq.in.
Empty weight: 53 oz.
aftcg 04-29-2002 05:07 PM
Where to purchase the Diablotin?
Where's the best place to buy one of these?
Did you get yours at your lhs?
What's the best price going?
David
Tuomo 04-29-2002 05:45 PM
Re: Diablotin
It's my favorit.
This engine recommendation is not correct. 120 is too much even for Std Diablotin -- 91 Fx being about the max.
modest-master 04-29-2002 07:42 PM
Distributor
The US distributor is: Esprit Model
www.EspritModel.com
:D :D :D
3Dreaming 04-30-2002 01:18 AM
Diablotin Super
I picked mine up from Esprit Models, as it is not an item the local hobby shop would have. I chose the Super for the extreme light weight. I put a couple more flights on it this evening, and I'm liking it more with each flight. One of my mods was to add a piece of 1/4 inch balsa to the aileron hinge line to double bevel it for more control throw. I'm glad I did this because at slow speed the roll rate is kind of slow. Tom
modest-master 05-04-2002 03:11 PM
Diablotins
Anyting new?
Tuomo 05-04-2002 03:29 PM
Another perspective. I fly Diablotin std with Irvine 72 and Apc 14x4W. This is a nice combo but very different from the Super. Diablotin Std weights close to 3kg. It is easy to hover, and is a very good allround performer. Perhaps little heavy compared to Laser 3D. If you want, you can also fly it in a semi-pattern style -- fast and smooth.
Does any have experience with the Diabolic??
