RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Which is a good pull-pull for rudder? (https://www.rcuniverse.com/forum/3d-flying-82/119854-good-pull-pull-rudder.html)
aftcg 04-29-2002 05:18 PM
I've got a 80" Lanier Cap with Brison 3.2.
I need to pull out the rudder servo (Hitec 615mg) out of the tail so I won't have to add weight to the nose. Looks like it would need atleast 8oz in the nose as is. I've read where taking a couple ounces out of the tail is equal to 6 to 8 oz from the nose because the tail is much further from the CG.
I've never used or installed a pull-pull system. Which one should I use?
Thanks for the help.
3DRC 04-29-2002 05:55 PM
Ck with Nelson hobbies. They have everything you will need.
Ryan Smith 04-29-2002 07:33 PM
Pull-pull rudder
Hey,
I have a Du Bro pull-pull system on the rudder of my Hydeout and I like it alot. The Hydeout is similar in size to that CAP so I think that it would probably do good. I cannot remember what size it is, but you can check on their website.
Chris 540 04-29-2002 07:41 PM
The 4-40 Dubro is whats going on my 29% edge...
Chris 540 04-29-2002 07:43 PM
Link
http://www.dubro.com/cgi-bin/SoftCar...661+1020143005
CrashMeister 04-30-2002 01:40 PM
See http://cih.home.mindspring.com/hobby.../PullPull.html
for a rock solid pull-pull system for the Cap.
Email me if you have questions.
Craig.
