RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   3D flying (https://www.rcuniverse.com/forum/3d-flying-82/121101-3d-flying.html)
fireman7875 04-30-2002 09:30 PM
3D flying
Do you necessarily have to have a radio with expo to fly 3D? How much can you do with plain old dual rates?
awat 04-30-2002 09:38 PM
3D flying
You can do 3D without expo. You just have to be very careful because the plane will be very sensitive.
Chris 540 04-30-2002 10:31 PM
3D flying
Yup...you don't need expo at all to 3D..it sure does help though...
Mike Bell 04-30-2002 10:39 PM
3D flying
Most of the guys I fly with that are 3D flyers don't use expo awat.
I fly 3D some and never use it
You have to remember to switch to low rates when the airspeed increases and stay high for a while. :eek:
Mike
fireman7875 04-30-2002 11:24 PM
3d
Thanks a lot guys. I was just curious because 3D has really caught my attention and was thinking of getting a 90 size extra to try with but I don't have expo. I appreciate the help.
Brian
ChixwithTrix 04-30-2002 11:54 PM
3D flying
why does expo help on a 3d plane? will just the normal thing do? how much exponential would i need for the 33% h-9 cap 232, though i wont be flyin it 4 a long time.
shmo46 05-01-2002 01:35 AM
3D flying
Depends on personal preference i guess. I like expo for normal flying, cause it makes even a squirly plane behave, but it actually seems to make hovering harder. I started with a lot of expo and runing 3D rates full time, but now prefere to just flip the rate switch. I run 20% expo at regular rate, and 0% for 3D.
Doug Cronkhite 05-01-2002 11:32 PM
3D flying
It's very much personal preference. I use expo myself, but many guys don't.
What I do is setup the airplane so that no matter what rate I'm on, the control surface deflection at 1/4 stick travel is always the same. This helps to prevent overcontrol when switching rates.
Just my ideas.. your mileage may vary.
-Doug Cronkhite
-Team JR
Mayur 05-02-2002 04:50 AM
3D flying
ChixwithTrix
its personal preference as everybody rightly stated. I use 40% expo for 3D setup....as you know control throws for 3D are huge (45 deg or more on elevator & rudder), such a high deflection is not required for normal flying. So you would want to soften the controls near the neutral using expo..it certainly helps!
Mayur
barryb-RCU 05-02-2002 03:31 PM
3D flying
I use the same approach as dcronkhite. Generally no expo at all on low rates and set the high rate expo so that 1/4 4 stick on high rates = 1/4 stick on low rates.
