RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Mounting rudder servo on Magic (https://www.rcuniverse.com/forum/3d-flying-82/1220390-mounting-rudder-servo-magic.html)
Tom Jones 10-22-2003 12:56 PM
I've seen the pictures of mounting the rudder servo back by the vertical fin, but how do you do it? Is there just a couple of pieces of hardwood glued to the fuselage skin to screw the servo into, or are there other things to reinforce? Thanks, Tom
George E. 10-24-2003 09:58 AM
RE: Mounting rudder servo on Magic
I stood the servo on the fuse, just in front of the fin and traced it with a sharp knife. Then cut out a hole and dropped in the servo. Servo screws went right into the top of the fuse. That's what I did with a mini servo, no reinforcing. A standard servo would be a larger hole, you may want to brush a little epoxy around in the hole to give it strength.
Tom Jones 10-24-2003 10:53 AM
geoharry-RCU. Thanks for the info. I'm suprised that there is no hardwood used. The epoxy is a good idea. I haven't got my plane yet, just trying to get everything in order. How thick is the sheeting back there? Thanks, Tom.
George E. 10-24-2003 01:16 PM
The fuse top is very thick basla near the vertical stab, maybe 1/4 inch thick from memory. I didn't notice any weakness after the hole was cut.
