RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Hovering/G2 sim (https://www.rcuniverse.com/forum/3d-flying-82/1250006-hovering-g2-sim.html)
MSP1957 11-03-2003 09:11 PM
Hovering/G2 sim
I have the G2 sim and just started trying to hover. I have a Cap232 that I am using in the sim. Is this the right plane to use to learn to hover with this sim? Any suggestions for settings, planes? Thanks
Michael
SeenMCrash 11-03-2003 09:15 PM
RE: Hovering/G2 sim
I use the CAP 232 to hover on G2. It's highly modified, of course. I think it weighs something like 5 lbs??? I run the Super Tigre 4500, with hover around 1/2 throttle. Make sure your control surfaces are huge and the deflection is huge. Much more deflection is needed for 3d than for sport flying. Good luck, Andrew
DMehalko 11-03-2003 09:15 PM
RE: Hovering/G2 sim
I dont know what upgrades you have but I like the 40% EDGE 540 for easy tourqe rolling
David
GoldenEagle 11-03-2003 09:33 PM
RE: Hovering/G2 sim
The stock 3D Sukhoi and the 3D Extra 330L both hover nicely with good torque rolls - just takes a good bit of practice.
JohnVH 11-03-2003 09:33 PM
RE: Hovering/G2 sim
Almost all the planes in G2 will hover with only a change of engine to give them enough power to hover. But you can edit other stuff to make it easy.
David_Moen 11-03-2003 10:01 PM
RE: Hovering/G2 sim
I have G2, but noe of the add-ons. Can anyone send me one of the included airplanes modified for practicing 3D stuff? I have found some "giant-scale" versions of the CAP, but they are ridiculously easy to hover and all but impossible to fly normally!
Thanks!
matlok 11-04-2003 12:46 AM
RE: Hovering/G2 sim
Keep practicing with the stock Cap - the only "3d" it will do is torque roll and the entry is a little tricky, but once you get to where you can TR it all day long and touch the tail, doing it in real life becomes EASY b/c you'll have learned to give the correct inputs quickly without really thinking about it. And if you can TR like that first, hovering becomes a non-issue.
Sprink 11-04-2003 04:45 AM
RE: Hovering/G2 sim
What adjustments do you need to make for the stock cap? It keeps snapping out on me. I'm currently practising on a 3D Ultimate I down loaded, but it is very easy and I need a bit more of a challenge to improve.
daveopam 11-04-2003 10:32 AM
RE: Hovering/G2 sim
down load the Goldgerg Extreme 330 profile. It is a little closer to actual R\C flight. It's not as easy as the Ult 3-D perso.
David
mike98624 11-04-2003 11:18 AM
RE: Hovering/G2 sim
where do you download planes for G2?
thanks
mike
Abraxxas 11-04-2003 11:40 AM
RE: Hovering/G2 sim
http://www.realflight.com/swap/index.html
I have had best results with using the Extra 330S as a beginning platform for 3D mods, if you have the addons 4 disk, download the Freestyle (SD) version of it from the swap page, this is an excellent start. Then tune it to suit your needs, I have 4 varients of this aircraft I regularly fly, each of them set up to fly a little different style of 3D... great plane. The stock Extra 330S 3D is what I used as my "hovering" sharpener and works quite well. The Edge is also a great plane to start with.
Have fun!
Rumple 11-10-2003 07:28 PM
RE: Hovering/G2 sim
Mike Badger has a great collection of RFG2 planes modified for 3D at [link=http://www.aero3D.net]AERO3D.net[/link]
You can get some nifty paint schemes too.
Kurt
EXCAP232 11-10-2003 08:03 PM
RE: Hovering/G2 sim
Try the download of the CAP 2X from the website. Better to learn from than the 3D CAP. Then go to the 3D CAP for more realism.
EXCAP232
