RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Learning to hover (https://www.rcuniverse.com/forum/3d-flying-82/1272208-learning-hover.html)
BasinBum 11-12-2003 03:54 PM
Learning to hover
OK, I have the 1/4 scale Extra that I will only try to hover way up where it does me no good. I built a SPA3D that was good for low down stuff and now I have a Morris Sledge that will be really good when I'm not afraid to loose it. Mostly I am practicing on G2 with a modified CAP232 and I usually get 2 or 3 rotations before I dork it.
So what have others out there done to learn to hover down low? Is it mostly sim practice? Lot's of ARF's? What are some helpful tips to speed up my learning curve?
Cactus. 11-12-2003 04:04 PM
RE: Learning to hover
have a look at my Cougar review, thats how i did it....
start in a wind, hover, then slowly slowly get the nose higher and higher and work the rudder more until your hanging.
problem is how a SPA3D and Cougar hang, it totaly different to how a low wing 3D or scale jobby hangs.
heres a susgestion, build a SPA3D with the extra's outline, inculding wing to tail relation and hopefully it'll make the rudder and feel more similar to your bigun than a funfly.
most of all burn gas and DON'T TOUCH THE GROUND!
daveopam 11-12-2003 04:06 PM
Your doing it the right way. Just keep after it . Stick time is the key even if it's on a sim.
All Thumbs 11-12-2003 04:47 PM
Forget the plane you're using in G2. As someone recommended in another thread, and that I'll now attest to...go to the G2 swap page and download the "Extra 330S Freestyle (SD)". Use that one, it's much more realistic and controllable. I'm not the world's foremost expert mind you, but it seems that most planes in G2 lose it too fast...then it seems like you can't correct any hovering mistakes. This plane is different. It might require Addons 4 though. I was using a modified CAP I downloaded and it wasn't bad, but still very frustrating...give that Extra a try and see what you think (it's already large in size too...also making it easier to see what's happening).
JohnW 11-12-2003 05:54 PM
Your on the right path. Sim time really helps a lot. I'd agree that you need to design or download a better plane. The stock planes in G2 don't hover relistically. I ended up making my own G2 plane. I basically learned to hover on the sim one winter. When the groud thawed, I was plesantly suprised that the real thing wasn't that much different.
The high/low thing is a catch 22. Up high, your're safe, but you can't see what the heck your doing. Down low, you can see what you are doing, but one mistake and your're in the ground. When up high, always practice bailing from hovers by powering up and out. Don't want to learn any bad habits when you move hovers down low. ;)
JohnVH 11-12-2003 05:55 PM
Keep working on hovering everything. Just takes time and lots of fuel! Stay on the sim until you can do it without thinking.
3-DFlyer29 11-12-2003 06:03 PM
Keep doing what you are doing now. I learned on the G2 cap 232. All it takes is practice. Try watching the canopy of the plane not the tail. When the plane is verticle it will look like it is falling on its back slightly but it isnt. Keep at it.
southern_touch9 11-12-2003 07:37 PM
If you modify the planes right they will torque roll all day long. I fly a modified CAP, Ulti, and Extra on there that I can torque roll the whole tank of gas out of it before it falls back to earth. Of course I have been doing this hovering stuff for a long time now :) If you know how to set it up right you can TR the mustang all day long too :)
DMehalko 11-12-2003 08:05 PM
Just buy a helicopter:D
David
southern_touch9 11-12-2003 11:05 PM
Helicopter [:'(]
BasinBum 11-12-2003 11:08 PM
Thanks for the advice and encouragment everyone (except you David). I am using a modified CAP from the swap page that will let me recover from falling out (within reason) and I'll try the Extra as well.
I guess I just need to stay on the sim more and transfer what I learn to the field. I just wanted to make sure I am on the right track and appearantly I am.
Abraxxas 11-13-2003 12:42 AM
Anything with enough power will hover, go to the recordings section of www.realflight.com and look for my movie. Hovering and TRing a completely stock B-17 with just bigger engines. Errr, if you have the right addons version that is. Otherwise you'll just see a PT40 :P Sim helps, thats how I broke my altitude barrier to get low enough to accidentally bump the ground [:-] You'll know your getting there when you can talk to somebody while you TR on the deck with the sim :D Not even thinking about the plane, your fingers are automatically correcting for what your eyes see... all while you think about that hottie you saw at the gas station on your way home from work...
BasinBum 11-13-2003 03:18 AM
AllThumbs,
I downloaded the 300s freestyle and it is definatley better than the modified CAP I was using. Quicker and more stable and it'll sort of flatspin. Thanks for the tip. BTW I am originally from Cleveland, just South of Eastlake.
sputknik 11-13-2003 08:20 AM
I am using aerofly pro sim and the model cap brietling ,can hold the hover pretty well .Any guys with both that can compare?ie g2vs afp.
southern_touch9 11-13-2003 12:29 PM
I agree with abraxxas about the sim. Once you get good at it you should be able to talk to people while doing it or talk on the phone while doing it. I dont pay too much attention on the sim while in hover. Its those dang rolling loops that take effort.
All Thumbs 11-13-2003 01:18 PM
BasinBum, you can thank some others for the tip, I'm just passing it along (it might have even been Abraxxas above you, I'm too lazy to check). Search or look for that other G2 hovering thread. It was started not too long ago. There were some other good tips given...like practicing knife edge with the bottom of the plane towards you...from all directions.
I'm learning to hover as well. Since you're from this area you know what the weather's becoming here (you should hear the Lake howling today!). I finished a Funtana and had three trips out to the field with it (11 flights). For now it's time for some heavy-duty sim time. I'm going to equate hovering with first learning to fly with your thumbs. Once you break the plateau you never have to think about it, but before hand, once you turned toward yourself it was white knuckle time. Hovering seems the same way, especially now that the instincts are becoming "slightly" automatic. Those guys above are right. I'll eventually have my thumbs on autopilot from the sim and I know that will translate pretty well to the real thing. Practice, practice, practice...no substitute.
Good luck
(hey, there's a couple of snowflakes in the air here today, any in California? :D )
BasinBum 11-13-2003 06:31 PM
Actually yesterday we had hail and it covered the ground and looked like snow but, today was high 60's sunny and 5-10mph wind. Typical for this time of year.:D
mithrandir 12-13-2003 02:23 AM
There is a lot to the setup or modifications to the G2 planes. Go to http://www.aero3d.net and download one of the big ULTIMATES. (http://www.aero3d.net/Ultimate/ultimate.shtml might work... some are just schemes, others are plane setups/mods) One of these planes (I forget which one) will hover and TR easily. Well... they have a lot of control authority! But the sim is great for developing the proper reflexes... It is great for things like rolling circles... with a roll direction change each 90 degrees... or starting out knife edge, rolling in, out, in, out!!!! and then rolling figure 8's!!! LOL... rG2 really is a great tool... and just remember... all these guys who can do the WHIZ-BANG aerbatics with a model... THEY HAVE NO LIFE!!!!! LOL.. I know.. THATS ME!! LOL
regards!!
yak_54 12-14-2003 05:28 PM
learned to hover at the end of my second flying season with a u can do .46 and a rossi .45.took a weeks vacation from work,was blessed with a weeks worth of good weather,and practice,practice,practice. the rossi took all the throttle management out of the equation.took full power with a 12.25x3.75 apc.entering from a downwind pop-up was easier than working it down from a higher altitude.os .70 added some power but also increased the tendancy to torque-roll.lots of time on the sim,more than i care to admit.PRACTICE MAKES PERFECT.or so i heard.my 2 cents
shouse 05-19-2004 11:11 AM
do you have to do anything to the cg to get it to hover? i have a dazzler and i love it it will do alot but not hover.
BasinBum 05-19-2004 11:37 AM
shouse,
From my experience a rearward CG will help but it is not the most critical thing to be able to hover. What I have found is more important are extreme throws on the tail surfaces, fast servos and a 2:1 power ratio.
Since the thread has been revived I'll give an update on my progress.....After finding the proper set-up on G2 I have been practicing regularly and have progressed to my satisfaction. The first month was frustrating and then I reached a new plateau very suddenly. That's the way it has gone for me, no progress and then all of a sudden I can do something better. I am now good for about 5 or 10 rotations and am starting to try and use ailerons to stop or reverse the roll.
I got a foamy electric and I can do everything on it that I can do on the sim, maybe even better. Yesterday I really was getting into a groove inches from the ground and for the first time found myself not thinking about what I was doing, I now know that is the ultimate goal, to not think.
My profile Edge is supposed to be excellent for hovering but I have yet to figure out the correct set-up and I think I need to change the pull-pull geometry to get better throws for 3D. I don't have the huevos yet to bring my 1/4 scale gasser down low enough to really be able to hover it well but given the progress I have made it will happen eventually.
rcflyboy90 05-19-2004 03:00 PM
I downloaded the extra300s freestyle (SD) and it will hover all day is really fun to play with and i made a recording with the plane they are all hovering and they all have diffrent color schemes. There is also a edge 540 (SD). That i downloaded.
rcflyboy90 05-19-2004 03:08 PM
Oh yeah if u build a pizza box flyer it will really make u a better pilot and it will teach u to hover. And wont brake if u crash it.
smokingcrater 05-19-2004 03:52 PM
ORIGINAL: rcflyboy90
it will help with orientation, but for general control it doesn't do much. (at least the PBF I flew WANTED to hover, and you had to try and keep it out of it...)
my suggestion is not to learn how to hover, leave that for the second objective. first practice getting yourself out of EVERY possible bad position when you lose the hover. you need to know exactly how to respond without thought.
DENNIS C 05-19-2004 04:10 PM
pratice & fuel:D
rcaviator-RCU 05-19-2004 08:07 PM
I guess I'm in the minority here as I don't care for the simulators.
My choice for hovering / torque rolling, and other 3D practice are the foamy electrics. You can hit the ground a bunch with minor or no damage most of the time. Plus it is a bunch of fun, to me the computer simulator is more work than fun. Another plus is that you can fly in very small areas, church, school or your front yard. Night flying in a lighted parking lot is a thrill as well. So my vote goes to the foamy electrics.
Practice and burn no fuel. :D
GarySS 05-19-2004 08:26 PM
rcaviator-RCU
As I know nothing about electrics what is your set up in your foamy?
1. Motor
2. Battery brand, size, other info
3. Charger system
4. Rx, servos, switch harness
5. Name of the foamy
Thanks!
Johnnylightning 05-19-2004 09:33 PM
ORIGINAL: BasinBum
*snip*
It will happen eventually, but only if you bring it down low and close. It's a catch 22
Example: You hover & T/R your foamy close to you, all day long, if you wish. Now, take your foamy up to about 50' hi and about 75' away from yourself and notice how hard it is to hover & T/R.
Like a ballancing act, these two maneuvers require precise input at the time, or even before they are required, to maintain this vertical attitude. There is a sweet spot, with very little tolerance in any direction that the aircraft must maintain, in order to sustain these maneuvers and there is no way to make note or anticipate these tolerances, in time, when the aircraft is too far away from yourself.
Take the plunge and cross the threshold...bring it down low. It's intimidating, I know, but you'll be glad you did.
rcaviator-RCU 05-19-2004 09:48 PM
Gary,
Below are my answers. Feel free to email me for a detailed write up I did for the local clubs, it's in a Word document. [email protected]
I also knew nothing about electrics before this.
ORIGINAL: GarySS
rcaviator-RCU
1. Motor
Himax 2015-4100 w/ Castle Creations 25 amp esc
E-Tec, 3 cell, Li-po, 1200ma
3. Charger system
Triton
Berg 5, Hitec 55, no switch
One I cut out myself and have modified through many revisions to get the way I like it to fly. A friend of mine cut the first one and I went from there.
Thanks!
BasinBum 05-19-2004 10:48 PM
ORIGINAL: GarySS
rcaviator-RCU
1. Motor-Razor 2500 /Castle Creations Phoenix 25
2. Battery brand, size, other info -ThunderPower 2100mah 3S
3. Charger system- Triton
4. Rx, servos, switch harness-Hitec 555 (remove the case) HS-55-no switch
5. Name of the foamy Foamy Factory Extra 40" or 44" from Depron
Thanks!
Goto foamyfactory.com to start out and learn where to buy everything.
I am able to hover it inches from the ground and grab it out of the air when I'm done. Rolling Harrier circles will be next.
CptCliffhanger 05-19-2004 11:17 PM
For me it was a Morris Top Cap ARF, TT pro 46 and an APC 12x4 prop.. And lotsa gas! You've just gotta dedicate whole flights to the effort!
People tell me that they just can't seem to get the hang of hovering. But when I watch them fly, I see them try once or twice, during the flight. The rest of the time they're doing loops and rolls and full throttle tumbles.. It's amazes me how much enjoyment some people get out of watching thier funfly plane flop around at full throttle with various full deflection crossed control inputs. :-)
My point is; you need to start with a disposable plane, that is capible of hovering! The Top Cap was a great choice, and still is. I'm afraid the Extreme flight profile edge is better than the top cap, but it wasn't available to me. :-( Besides that you need to know that the only difference between people that can and cant hover is hours of prectice! People will give you all sorts of advice or tricks that will help you hover. Some good some bad! :-)
Fly the piss out you're plane, and write back when you've got it! :-)
The best advice I can give;
1) Learn to hover your plane with enough altitude that you can pull out of anything.. I'd say ~ 40 feet. The key is not to get frustrated at the fact that you're not staying in the hover for very long. At this stage the goal is not to hover, but to learn to recover control of the plane without loosing altitude.. The plane is too far away to to see the subtle changes in attitude that you need to correct for. Just get good at recognizing when the plane has fallen out of the hover, wich direction it fell out, and what control inpu is needed to recover without loosing altitude.. example. when the plane falls onto it's back, adding power and DOWN elevator, and not pulling up completing the second half of a loop before recovering, or trying to roll to upright flight first then pulling up. This wastes altitude, wich you wont have when you get to step 2
2)Now that you can recover from any attitude without loosing any altitude, Bring it down low! This is where it gets fun! Now you can really start to see the subtle changes in attitude and you can start refining your inputs to keep the plane upright.. Obviously it's easier to keep the plane in a hover if you're looking at the top of the plane.. You can use right aileron input to counteract the engine torque, but most people don't realize that if you input just a little tinny bit of down elevator the nose will creep forward and the plane will no longer have the urge to torque roll.
3) Torqu roll.. Hmmmm Just gonna have to practice that one!! :-)
Hope this helps. :-)
Stephan
