RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   PLANE FOR DA50R (https://www.rcuniverse.com/forum/3d-flying-82/1275847-plane-da50r.html)
mAvRiCk-inactive 11-13-2003 09:27 PM
PLANE FOR DA50R
I am interested in finding a plane for the DA50 that is and ARF. I want it to be between 15-18 lbs.
Also, with a wingspan of 84"-90."
Please reply to this guys. I ned lots of help
dan
blue ice 11-13-2003 10:25 PM
RE: PLANE FOR DA50R
I too am looking at planes for a DA50. Wildhare and Extremeflight make some you could look at. I have put my name on Chip Hydes list for a Double Vision. We will also be purchasing a Dave Patricks Edge 540T for my girlfriend. Have not decided if we will use a DA 50 on that or maybe just a ZDZ40. Good luck with yous search.
DKjens 11-13-2003 11:17 PM
RE: PLANE FOR DA50R
1 Attachment(s)
What kind of plane you looking for? 3D funfly, scale aerobatic? I just received my new DA50-R yesterday, what an absolutely gorgeous piece of machinery. I am picking up a DiablotinXL tomorrow or Saturday for this engine. I had one before, but with a zdz40 in the nose. The DA50 is lighter and stronger, it will be a 3D blast. I am also getting the WildHare 28%Edge540T, and I am getting one of the new mvvs58i engines for that plane; the engine should arrive early next week. For a 3D plane, the new DV looks great, and at same price as Esprit charges for a DiablotinXL. I am getting my DiablotinXL kinda locally (120 miles) at a good price and without the $70.00 shipping fee. I have attached a picture of the DiablotinXL I had earlier this year - I sold it.
DKjens
torquerolln 11-14-2003 02:55 PM
RE: PLANE FOR DA50R
i heard the Diaboltin XL were realy weak and break easy. Joe Hunt told me so...whas ur opinion?
DKjens 11-14-2003 08:06 PM
RE: PLANE FOR DA50R
Only thing that broke for me was the top of the rudder. I think I was doing some bit fast knife edge, and the top just folded over. I insserted a carbon rod and glued kevlar tape to the outside. The fuse held up well, didn't have any joints come unglued, and I did do harrier landings with mine. The new one will have a large (taller) composite under carriage, since I'll be swinging a 24x8 prop after break in of engine. Also, stock gear put the plane pretty flat, and it needed some ground speed to get in the air - I want it to just jump in the air.
I spent time and energy double bevelling the rudder and elevators on my first one, but I'd like to hear opinions on whether beyond 40-45 degrees of throw is actually beneficial.
DKjens
RobT 11-14-2003 10:48 PM
RE: PLANE FOR DA50R
Were you looking for a Kit or an ARF?
AS a Kit I would go with a Midwest Cap. GREAT combo with the DA 50. I had one until someone walked up with his checkbook and wrote a check an put it in his car. I wil have to build another one day.
If you are not an kit builder the Extream flight Yak looks like it is worth a look see.
Rob
paulplevoets 12-28-2003 12:36 PM
RE: PLANE FOR DA50R
I've also got a diablotin XL, but I have a ZG-62 on it. This engine is realy shaking the plane in pieces. Wich prop (size+brand!) do you guys use to fly 3d?? What engine? Thanks,
Paul
mAvRiCk-inactive 12-28-2003 12:51 PM
RE: PLANE FOR DA50R
Im not with the DA engines anymore...i fly 3W now...that plane is built too light [X(]
Dan
DKjens 12-28-2003 01:05 PM
RE: PLANE FOR DA50R
I don't think the DiablotinXL is built too light. When I had mine with the zdz40 on it, I would swing a 20x10 or 22x8. I did not have problems with vibrations, I also made harier landings without damage to the plane. I G62 in the nose will make this plane super nose heavy, and alot of weight will need to be added to the tail. With my 40 I had 4 servos in the tail, and with radio gear mounted per instructions, it was nose heavy. I cut a hatch in the fuse under the canopy, reached back in the fuse as far as I could, and mounted my Rx battery to the floor, the Rx was just below the pilot, and it still did not exhibit extreme tail heavy ness. I just lost my second DiablotinXL/DA50R combo on its second flight due to complete lock out, but I am getting a third, also for my DA50R/header/KS can engine. I just use one HS5945 on each eileron and elevator, and the new one will have two HS5645 on rudder.
Tthe do need a taller main gear though, especially with a 24" prop that I will swing on the DA50R.
DKjens
wild fred 12-28-2003 07:06 PM
RE: PLANE FOR DA50R
a friend at my field has a g.p. patty wagstaff with a da 50, flies great and fairly cheap; and not much difference in glide than the 2 moki powered ones here.
hovermaster 12-28-2003 08:10 PM
RE: PLANE FOR DA50R
Extremeflight rc 87" yak 54
blue ice: your girlfriend flys.... cool.
Chris
wild fred 12-28-2003 09:22 PM
RE: PLANE FOR DA50R
how does that yak fly? anyone got one yet? I have never seen one personally. one of my flying buddies wants one, but who knows? last yak I flew was a controline in the 70's:D
blue ice 12-28-2003 11:03 PM
RE: PLANE FOR DA50R
She sure does. In fact we had a break in the weather today and both got in a few flights.
We may be getting the DA 50 for the Edge. I haven't real made up my mind yet.
3DFanatic 12-29-2003 12:51 AM
RE: PLANE FOR DA50R
Wildhare 28% Edge (ARF)
or Aero-Works 28% Edge (Kit)
hovermaster 12-29-2003 03:36 PM
RE: PLANE FOR DA50R
1 Attachment(s)
I havent flown the Yak yet, but i cant wait till we get ours. Right now we put our BME 50 in a custom made 84" Flip 3D.
Chris
