Flapperons V.S. Spoilerons
I want you guys to define both of these terms for me (as related to 3D).
RE: Flapperons V.S. Spoilerons
On Fun fly Planes I use spoilerons to dampen the wing rock in an elevator. About 80 % in relation to the elevator movement. I also use flapperons to make my loops tighter. You will have to play with the percentages with each plane. As far a hovering and knife edge I cut both of these mixes off. On most of my planes I have the elevator coupled to the rudder(master) to eliminate the pitching, and this is set up as a permanent mix.
Man, this is really a Burning Question for you, huh?? :D
| All times are GMT -8. The time now is 07:39 AM. |
