RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Hovering U-can-do 46 (https://www.rcuniverse.com/forum/3d-flying-82/1416813-hovering-u-can-do-46-a.html)
Rotcivv17 01-09-2004 09:59 PM
Guys will the U-can-do 46 hover with an O.S. 15 LA??
rightflyer 01-09-2004 10:03 PM
RE: Hovering U-can-do 46
I hope this was a serious question-no, it will not hover with a OS 15 LA. Hence, the name UCANDO 46. Use a 46BB or better
Rotcivv17 01-09-2004 10:05 PM
ohh, I got a Cox .046, will that do it? After all it IS 46
Dewey2 01-09-2004 10:09 PM
it should work fine. i had a norvel 049 on mine it hover at 1/3 throttle with my fire water mix. you should hang at around 1/2 throttle.. and think how much you will save on the wing loading[8D]
i have herd of a satio 100 on one but i think he was from mars very low air up ther.
Tec 01-09-2004 10:12 PM
roticvv,
Good one! I guess i'm not the only one how is tired of reading the same BS every day? Just think I've been away from home for 40 days and did't miss a thing.
3DFanatic 01-10-2004 02:33 AM
Mine's absolutely balistic on a peewee 010. I have my battery/rx/servos right on the firewall to balance it out though :D
flyhuntfish 01-10-2004 10:21 AM
I have found that if I reely manage my speed well, it will hang with just a good hard toss, so I took my satio 1000 off and reealy saved wate. Now it ways 1/3 of a gram and and is a reel floter.
Seriously, I have heard that the Saito 72 is a perfect combo for the UCD 46 or put on a quality 2 stroker such as the OS 50. Why buy a Porsche and put your old Geo motor in it?
I have a UCD 60 and power it with a Saito 100 using an APC 16-4W prop. Hovers are around 1/2 throttle and unlimited vertical is not a problem although accellerating through a series of snaps on a vertical upline out of a hover are beyond the engine's thrust capabilities. (I have seen this done with a 40% Edge powered by a 3W150 and it is very impressive!)
southern_touch9 01-10-2004 11:29 AM
:D Personally,
I dont think that the light motors will do it justice. For 3D you will need a gas motor. Maybe you should put a G-38 on there. I have one on mine and its just a site to see.
[:@] This is one of my biggest R/C pet peeves...Guys that put gas motors on 1.20 sized and smaller airplanes and wonder why it doesnt 3D all that well.
qweedqwag 01-10-2004 11:51 PM
My what a sarcastic lot.
halfandhalf825 01-11-2004 06:28 PM
What a freaking idiot??!!! LOL L
