H9 Funtana ground clearance and servos
I am putting a Saito 91 on my H9 Funtana. Is there enough ground clearance with the stock gear for 15" props? I'll probably try APC 15x4w. I suppose a 14x6 would work as well for increased ground clearance. I see people buying carbon fiber gear but is this necessary? Also will Hitec 475 servos be enough in this plane? They are 76 oz at 6v with a top ball bearing. The nice thing about these is they are cheap too.
Thanks for any info. Chris |
RE: H9 Funtana ground clearance and servos
Chris,
The 15" prop will clear with the stock gear. I run a Saito 100 in mine and have found the 14x6 to work well with this motor on this plane and gives me that bit of extra clearance. Hope this helps. Eric K. |
