Need a 3d plane sugestions
i want a 3d plane that does all the 3d moves and pattern moves artf for an asp .52 around £100 is this asking to much i wanted the capiche but i dont have the money ill get it at christmas next year for a winter project. THANKS b.t.w i dont want a profile
RE: Need a 3d plane sugestions
You could get a h9 funtana or get a kyosho flip 3d. The flip is 230 in american dollars i think a 100 pounds is about 210 here if you want to go the extra get the flip in my opinion or get the funtana which is well in your price range.
Cheapest Flip I have seen is about £160. I think the Funtana is a bit cheaper, about £150.
funtana needs a better engine than that. id say so does the flip
where can i get a funtana in the UK what size ingine does it need and will 3001s do for servos or what is the absoulte minimum
ill get a two stroke or ASP 4 stroke 91
A funtana aparently needs at least a saitp 91 soi think its out of the Q. 3001s wont be enough really. Anyway, if you cna afford a funtana the capiche is cheeper and it will run right good on a the asp 52
but i cant be bothered to build a kit even a quick build
check out the veko 3d
here you go look at the sport section and at the bottom you will find the veko http://firstleader.nease.net/ |
ORIGINAL: bn120 check out the veko 3d here you go look at the sport section and at the bottom you will find the veko http://firstleader.nease.net/ |
| All times are GMT -8. The time now is 06:22 PM. |
