RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   3d Control linkage setup (https://www.rcuniverse.com/forum/3d-flying-82/1519313-3d-control-linkage-setup.html)
mnrcaerobat 02-11-2004 07:40 PM
I am not having any luck getting alot of throw on my Funtana. Can someone post a pic or advise me how to set up my plane to get max deflection. I am using standard (supplied) horns, hitec 605 servos, and supplied linkages. Do I need to buy Dubro servo arms and control horns? Is there other equipment that will work better?
going vert 02-11-2004 08:20 PM
RE: 3d Control linkage setup
I don't have a funtana, but on all my 3D type planes, I use long servo arms - dubro are fine for the funtana.
3D ONdaEDGE 02-11-2004 08:53 PM
I am having the same problem on my elevator. I can get the recommended throw of 40 degrees, which may be enough, but i like having a little extra to be sure. You would think that it would be enough since they designed it for a 3-D plane and they say 40 degrees is enough. Ill try it this weekend and see. As far as everything else i am getting plenty of throw. My ailerons are at about 60 degrees and my rudder is touching my elevators. I have Hitec 615MG's with the aluminum servo arms from my dads Hitec 5945 hardware. I also have 4-40 linkages with ball links and metal clevises. The control horns are stock though. I just pray that mine doesnt have the sanpping problem that some of the other funtanas have had. Good luck with yours.
Shortman 02-11-2004 09:01 PM
Umm, you could start by using high quality metal servo arms such as (maximum length of 1-1/4")SWB (www.swbmfg.com) Hanger 9 metal arms (www.horizonhobby.com) or Sure Link if you really were serious (www.sure-link.com)
You then can use a ball bearing swivel ball link (Hangar 9 took over Rocket City and sells them) 4-40 Heavy Duty ball links attached to the metal arm
Use Hangar 9 Titanium Pro Links for pushrods and then use a quality control horn like maybe www.cactusaviation.com sells, and either another ball link for that or use a steel clevis which again Horizon Hobby sells.
That is a very very solid linkage proven in many of the GS planes and pros.
If your still not getting desired throw, then buying a kit and building it and doing a proper double bevel will do.
40 degrees should be a good amount for 3D flying
