RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Another UCD post (https://www.rcuniverse.com/forum/3d-flying-82/1560615-another-ucd-post.html)
antman450 02-24-2004 04:49 PM
Another UCD post
I am building another UCD 60 and I am putting a Magnum 120 2 stroke in it. I have heard that people have done this and I tried it on my last UCD 60. I had to re-drill the firewall to fit the larger motor mount, but the holes were so close to the sides of the firewall that I had to cut into some of the triangle stock so that the blind nut could fit. How have any of you guys done this? I am wondering if cutting into the triangle stock will weaken the firewall too much.
I was thinking that maybe I can drill teh motor mount to fit the existing firewall holes.
Another thing. i am mounting th tank on the CG. Now there will be that big hole on the firewall where the stock tank fits. What can I do to block that hole up so that fuel will not go into the fuselage.
Thanks for the replies.
antman450 02-26-2004 04:40 PM
RE: Another UCD post
No replies?
PeteJoMan 02-27-2004 05:42 AM
Go to your LHS and buy/order a Dave Brown engine mount P/N 120F-1204. This mount puts the firewall hardware more toward the centerline of the engine than conventional "square" engine mounts eliminating the need to cut into the tri-stock on the firewall. Lite ply cut to shape should cover the hole in the firewall quite nicely.
PeteJoMan 02-27-2004 05:45 AM
Oh, and i almost forgot, Do not, under any circumstances, weaken the firewall.
