RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Razor 3D ARF (https://www.rcuniverse.com/forum/3d-flying-82/1565327-razor-3d-arf.html)
SIDEWINDER 3D 02-25-2004 10:07 PM
Razor 3D ARF
what do you guy's think of the Razer[sm=confused.gif]
Justin
3DFanatic 02-26-2004 12:36 AM
RE: Razor 3D ARF
Well, it's Lanier...Nuff said :D
splais 02-26-2004 01:14 PM
RE: Razor 3D ARF
I've had two. Crashed the first one when I accidently crossed the ailerons. I posted some place on them. Long story short: construction-wise one was awesome, the other was crap! As stated above, it is Lanier, you takes your chances.
As to flying, the plane is awesome, one of the widest flight envelopes I have seen, pattern to 3D, slow to fast. The plane is not for a beginner. I have a YS63 in mine. Weighs 4.5 pounds. I have limited 3D ability, but I think this plane will do anything anybody would want it to. It's control surfaces are huge and so are it's high rate throws. Nuff said.
3DFanatic 02-27-2004 01:19 AM
RE: Razor 3D ARF
Aileron's are kinda small...[:o]
splais 02-27-2004 10:14 AM
RE: Razor 3D ARF
But it is a dual-purpose plane, and seems to do both very well. Actually it could use triple rates on elevator and rudder if you know what I mean. [:-]
SIDEWINDER 3D 02-28-2004 02:01 AM
RE: Razor 3D ARF
what did u think of the beel crank
Justin
coyote 02-28-2004 11:22 AM
RE: Razor 3D ARF
Bellcrank is a good idea but the one on the Razor is a POS and allows quite a bit of slop in the elevator linkage due to a sloppy fit. Fuselage pivots cause quite a bit of friction. Ball bearings would have been nice. Will have to keep an eye on this and possibly go with two elevator servos.
splais 02-28-2004 11:11 PM
RE: Razor 3D ARF
ditto the bellcrank being ****. In theory it's a good idea, but EVERYTHING Lanier makes is cheap crap. you can get a MK from Central Hobbies for about $35. Depending on your engine and balance a couple of mini servos might be good.
I will give you one other warning. you can take it for what it's worth. I will never again order any Lanier plane through the mail. Their QA is the worst I have ever seen. Of two planes and one wing I got from them; one plane and the wing were damaged (not in shipping) and other stuff was absolute crap (cracked sheeting, separating plywood, etc). You got about a 50% chance of getting a good plane from them.
3DFanatic 02-29-2004 01:06 AM
RE: Razor 3D ARF
I know a guy that had a lanier razor and the bellcrank was rock solid.
SIDEWINDER 3D 02-29-2004 11:33 AM
RE: Razor 3D ARF
the bell crank was vary slopy on my plne so i cut it out and made a different set up with tree cntrol rods.
dbow 03-26-2004 08:17 AM
RE: Razor 3D ARF
I began working on my Razor a few months ago, I had to make a lot of modications. I found the same as depicted in previous posts on this thread....The bellcrank had a lot of slop.
I found that the arm in the center of the shaft moved back and forth on the shaft a great deal. I tighthend the set pin but this did not help. I removed the set pin and tapped the center shaft for a screw. This solved the problem.
I also found the arms on the outside of the shaft going to the elevator horns to be to small. I replaced them with Hitec servo arms and also tapped the shaft with screws to hold them on. Seems to be working great so far.
I have finally completed this plane but have not flown it yet, should fly this weekend.
I will update my previous threads on this model sometime today or over the weekend.
By the way the plane came out 4-1/2 lbs.
Dbow
3DFanatic 03-27-2004 12:06 AM
RE: Razor 3D ARF
That seems pretty light... What engine?
Dan767 03-27-2004 03:08 AM
RE: Razor 3D ARF
I have this airplane. There is a trick to get the elevator bellcrank set up correctly to avoid the slop. What I did, was:
1. Put in the elevator servo, with the control arm.
2. Install the bellcrank with the pull pull cables attached.
3 Run the cables forward to the servo arm; slip the "crimp" over the cable.
4.Run it through the servo arm and pull it snug. Put the other end through the "crimp" and squeeze the "crimp".
5. Repeat with the other cable.
6. Trim the ends of the cable and remove the tape from the elevator.
My bellcrank assembly works like a charm.
Use some expo on high rates. The ailerons get "twitchy" without it. I'm using 45% on the ailerons, and 25% on the rudder and elevator. This is my third Lanier airplane. (Cap 232 80" kit, 30% Edge 540T, Razor) More than likely, if they come out with something else I like, I'll buy that too.
3DFanatic 03-27-2004 03:27 AM
RE: Razor 3D ARF
Yup, Dan you're the 0-slop guy I was refering to earlier :D
SIDEWINDER 3D 03-30-2004 12:44 PM
RE: Razor 3D ARF
my elevator work perficly now
3DFanatic 03-31-2004 01:36 AM
RE: Razor 3D ARF
yaaaaah
sir-crash-alot 04-04-2004 12:04 AM
RE: Razor 3D ARF
Hey I just got my Razor, The bell crank was sloppy so i got heavy duty horns for more throw and i opted to get hevy duty clevis's for the area around the evelvator. It works awesome. Oh, Yeah what the heck is up with the small ailerons. Im using a O.S 70 with a perry pump to power it. Another thing invest in a prcision servo for the elevator with a long arm for even more throw! Happy Flying
3DFanatic 04-05-2004 01:22 AM
RE: Razor 3D ARF
Ya..the tiny ailerons are a bit odd... That 70 should make it a schweeet combo.
Dangerous Dan 06-01-2004 01:26 PM
RE: Razor 3D ARF
perry oscolating or v-30
splais 06-01-2004 02:31 PM
RE: Razor 3D ARF
You don't need to worry about the "small" ailerons. They will look at lot bigger when you get into a high rate roll[:-]. Keep in mind this was designed as a dual-use aircraft between Pattern and 3D. It does both relatively well. Just wish this plane was built by a company with a little better QC.
3DFanatic 06-02-2004 12:39 AM
RE: Razor 3D ARF
That's why there's the Goldberg Matrix ;)
dhooks 06-02-2004 01:39 PM
RE: Razor 3D ARF
Correct me if Im wrong but didnt Lanier buy Goldberg and is now producing there planes? The Matrix I have is HEAVY at 6 lbs 6oz.
Dan
nmking09 05-26-2011 04:22 PM
RE: Razor 3D ARF
IT's BAAAAAKKKK... I have flown one of these and it is AWESOME, under 5lbs with a .46
Tower has them on the way.
