engine for u can do 60
Hi,
I use a os fs91II with my u can do with a apx 15X4w prop . seems the engine doesn't have enough power (easpecialy to climb out from hanging the plane ). Anyone has the same problem with this engine? , what would u reccomand? Thanks for help [&o] |
RE: engine for u can do 60
I think a DA 150 would be perfect. Maybe even a little underpowered. LOL
Seriously, in my opinion this plane needs to be overpowered. I had an OS 91 fx and it just did not have enough pull in vertical and out of a hover. I replaced it with a Magnum 120 two stroke and I love it. I mean the power is unbelievable and the plane still floats perfectly. Flies very light....battery in the tail and the CG is at 5 7/8. I am under the impression that a YZ110 spins that same size prop at the same speed as the Magnum 120....Can anyone input on this? From what I have heard a YZ 110 is very good for this plane too. I want to get a 4 stroke so I may get the YZ 110, but I have also been pondering the YZ 140. Anyone's info on this would be great. |
stick with the two strokes ive had 2 with fourstroks and i with a 2 stroke both 91's the 2 stroke is a 100% better
Dori, the consensus is pretty much Saito 100
1 Attachment(s)
Or, you can try a RCS 140 gas engine. it works for me
| All times are GMT -8. The time now is 01:14 PM. |
