RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Roll and pitch coupling (https://www.rcuniverse.com/forum/3d-flying-82/1711689-roll-pitch-coupling.html)
zimm 04-11-2004 07:58 AM
Hello Mark,
What are your suggestions on mixing out roll and pitch coupling for knife edge purposes? Control on a switch or part of a flight mode ? I"m flying a Funtana 40, Katana 140.
thanks,
Zimm
Ultimate 2003 04-15-2004 12:00 AM
RE: Roll and pitch coupling
I fly with the mix on at all times.
Use a P Mix for Rudd-Ail and Rudd-Elev
Start with a linear curve and work your way up to a curve mix. IE when the airplane is slower and you need more diflection, the mix required is greater.
Take it one step at a time and don't rush it.
Remember Practice doesn't make perfect, Perfect Practice makes Perfect.
Mark Leseberg Jr.
TheEdge 05-13-2004 04:40 PM
Mark, I just bought your 2M Funtana
Any tips on the set up for this plane?
Thank you in advance, Bob
SAL98 05-13-2004 08:14 PM
Hey Mark, Your answer to that last question really helped me alot. I always wondered if I was suppose to add more mixing in a high alpha knife edge compared to a normal high speed knife edge which usally requires about 3-4 % mixing. I didn't know if guys were just Flying the sticks more in high alpha .
Next time out I will try and add more mixing for points 1 and 5 on my 9c .
This really does tak time but I find it helps my rolling harriers tremendously.
