U Can do 60 engine help
Is the Os 91 fx going to be able to pull out of a hover quickly on the U can do 60
I have a Os 108 on order but I was checking the power to weight and this is what I found 108 27 oz 3hp 91 19oz 2.8 hp Which engine will perform better? Thanks Mike |
RE: U Can do 60 engine help
the os 108 it makes its power at a lower rpm thats good. i flew one with a 91 for a while it was slow on pull out ok by some people. if thats your only picks run the 108 the plane will take just about any engine you can bolt on .:)
I second that ...[sm=thumbup.gif]
I use the YS 110 FZ with a 16x6 APC ....it'll hover @ 1/3rd throttle and pull out very fast if neededd....JW |
| All times are GMT -8. The time now is 07:13 PM. |
