RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Pull Pull Linkages???? (https://www.rcuniverse.com/forum/3d-flying-82/187795-pull-pull-linkages.html)
skerlock 07-08-2002 02:49 AM
I have a hanger 9 540 Edge....I want to move my Rudder Servo further back about 4-5 inches or so...In doing so I would like to replace my Pull Pull set up with a new one. WHERE CAN I FIND THEM. Central hobbies..NO, Tower..NO, Horrizon..NO, Gator R/C...NO,
Please Help
Scott
EXCAP232 07-08-2002 07:46 AM
Pull / Pull
Sullivan makes them.
Precision Avaition design has a really neat one (Bob Godfrey)
Dubro has 2 weight ones (2/56 and 4/40)
Bill
Mayur 07-08-2002 09:58 AM
u can get the dubro from towerhobbies..
http://www2.towerhobbies.com/cgi-bin...1&I=LXD858&P=0
mayur
skerlock 07-08-2002 01:23 PM
Thank you...I couldnt find the dubro at tower for the life of me..
Scott
ScottK 07-08-2002 06:23 PM
Re: Pull Pull Linkages????
Please Help
Scott
Or...just go down to WalMart and buy some "SpiderWire" coated stainless leader of the appropriate diameter for your use. I believe it comes with the crimp sleeves, but you can buy extra crimp sleeves separately as well.
If you need couplers, Dubro sells rigging couplers and Sullivan sells threaded eyebolts with jam nuts.
Scott Kantrowitz
racer rob-RCU 07-09-2002 11:45 AM
pull/pull
you can also try dons hobbies they have them, also in three sizes, coated kevlar i believe check them out on the web
JWN 07-09-2002 02:02 PM
I build my own pull/pull cables from fishing tackle. Buy a spool of nylon coated stainless steel leader material and a small bag of crimp sleaves. Total cost so far, about $6.00 and you have enough stock for 4 or 5 models. For the cable ends, Dubro sells them in a package of either 2 or 4.
John
Flyboy Dave 07-09-2002 07:29 PM
Wire
JWN....Thanks for that one....sounds good. I bought a pull-pull "set" from Cermark, and the wire is so thin and wimpy-lookin'...I will never use it. Dave
JWN 07-09-2002 07:32 PM
No problem!
Dave,
What's nice about using fishing leader is that YOU choose how heavy a wire you need. If you decide you want to install pull/pull on a 60 size model, you can choose something a little lighter than you would probably choose for larger aerobatic bird. There is a lot of customization you can do when you roll your own :)
John
Flyboy Dave 07-09-2002 07:39 PM
Wow....that's even better ! I would have never thought of that one...Thanks again....Now I have to run down to a tackle shop, cause I wanted to see if they have such a thing as a digital fish scale... for weighin' planes......Dave...
JWN 07-09-2002 07:43 PM
One more thing
I'm sure you would notice this when you went to the store, but make sure you get the flexible leader and not the solid wire stuff. The flexible leader comes on a fairly small spool and is multi stranded with a nylon coating. Most I have seen is brown in color. There is another leader material that basically looks like shiny music wire. I wouldn't use this stuff as I'm afraid it might get brittle with age and is too stiff.
Happy fishing :)
John
hmorin 07-09-2002 08:49 PM
check out Nelson hobby in Oregon. He sells all kinds of cool stuff including multiple pull/pull systems. I am using his dual servo system on my 1/3 scale 300L.
Howard
