RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   electric smaragd freestyle (https://www.rcuniverse.com/forum/3d-flying-82/1917228-electric-smaragd-freestyle.html)
Rhilluk 06-19-2004 04:55 PM
1 Attachment(s)
well this is my new baby, not much interest on the pattern forum, but here's some piccies, I have two kits, so the next one I'm going to cut even bigger controls in her. But she got a
hacker C50 13xl
hacker opto 90 esc
flightpower batteries 10s2p 4400mah
elev 2 x 9001
rudd 645MG
ailerons 2x hs77
weight will be approx 9.5lbs
Shahid 06-19-2004 05:02 PM
RE: electric smaragd freestyle
Very nice, have fun! How do you pronouce it again? strange spelling.
I wonder why people donmt import these more, they are such nice kits.
Luke 3D returns 06-20-2004 02:31 AM
Nice, looks like youve trained your guard dog well!!:D
Ian.W 06-20-2004 04:46 AM
Shahid, the plane was designed my wolfgang or roland mat and all their planes are named after rubys or emeralds. this one is some sort of ruby in the lithuaniesh launguage
Rhilluk 06-20-2004 05:08 AM
it's german emerald, they still import them, just been modified to the lazulite, the canopy has been moved forward to increase side area for better knife edge manouvers.
robhoneycutt 07-04-2004 05:37 PM
Interesting approach to go with the 2P config.. I guess you will prop it for 45 amps wot or so.. the extra 13 ounces of battery (if you went to 3P) sure would give you more power. The motor and controller can certainly handle it and the power curve between 45 and 60 amps is almost linear.
Good looking plane!
Rob
Rhilluk 07-04-2004 05:52 PM
these cells are supposed to be able to go to 14c confortably and peak at 20c, but then the 3p config would give a confort zone. however I can still push 60 amps from the 2p pack. The new kokams apparently go to 23c allowing me to run just a single p pack, losing another 1lb hopefully weighing in at under 9lbs.
robhoneycutt 07-04-2004 10:59 PM
Based on how these guys over here ,'throttle', the duration would come into play, not to mention the prime "20C" discharge rates you are speaking of...
So even if the batteries hold up to the rates, the duration would not be too long at all... Not sure it's worth the weigh saviings......
Great plane and can't wait to hear how it performs electric! it might be the first SM@#$%^ that's electric!?
Rob
Rhilluk 07-05-2004 03:00 AM
I'm hoping I won't go much over 60 amps, it's been bench run at 55 amps, that's with a 20x12apc(e). Thats probably the most it will draw what with the plane moving in flight there should be less load on the prop so less current. Most guys who use this setup are getting 12mins+ plenty for a pattern slot.
Shortman 07-05-2004 12:59 PM
Either that or try the newer Gen 2 10-12C Thunderpower batteries. They underrate their batteries and the quality is above the rest.
Rhilluk 07-05-2004 04:21 PM
I'm going to experiment with batteries, hopefullly be able to collect a few as I'm now starting a Capiche 140 leccy plane. ANd I can interchange them between models.
Ian.W 07-06-2004 02:18 PM
richard, try the new flight power 10s2p packs, well, there 2x 5s2p and they are unbelievavble, just like daves got in his C140
Rhilluk 07-06-2004 02:38 PM
ed, read my spec!! :D
Rhilluk 08-11-2004 11:09 AM
1 Attachment(s)
just an update everything is in now, just finishing the covering.
Thats the 3styla on top to show size - I love it :D:D:D
Any ideas how to fix the batteries in?
Ian.W 08-11-2004 11:25 AM
nice.
batterys: how about velcro straps, thats what the ION-X uses and that flyes 3D
The boys Back 08-11-2004 01:08 PM
Wat the FK you done to the undercarrage!! its round the WRONG WAY [:'(]
Rhilluk 08-11-2004 01:50 PM
Oh s**t.[:@]
For 3 months it's been like that and I haven't ever noticed, that will sort out the ground clearance too - :D
Thanks Dave
Rhilluk 09-21-2004 08:16 AM
1 Attachment(s)
It's finished, hooray
Only need the batteries to be returned from Flightpower - once they get off holiday.
Shahid 09-21-2004 08:38 AM
Lurverly [8D]
C140 Brothers 09-21-2004 08:52 AM
lookin good (just turn the u/c around)
Luke 3D returns 09-21-2004 10:01 AM
Could say the same for your 140ex Kane!
C140 Brothers 09-21-2004 11:29 AM
SHHHHH,luke
Ian.W 09-21-2004 11:30 AM
lol:)
any colour going on it?
Rhilluk 09-21-2004 12:21 PM
yeah, but I'm undecided on that Ian, can't make my mind, just getting a creative block.
Rhilluk 10-20-2004 04:21 AM
damn this weather, all ready to go, I mean it this time, all ready to go and look at the weather, just look at it. And the only day that is looking good is sunday. The one day I don't want to fly cause they'll be too many people up there. Why does he tease me!!!!! AAHHH!!!
