RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   3D Power source poll (https://www.rcuniverse.com/forum/3d-flying-82/1976391-3d-power-source-poll.html)
YS-I-DO 07-09-2004 07:56 PM
If you had to choose between an electric foamie or a scale/profile glow/gasser for the rest of time, which would it be?
Spaceclam 07-09-2004 10:29 PM
RE: 3D Power source poll
definatly the gas.
definatly a ys.
Ian.W 07-10-2004 10:06 AM
gas is good. however i just love the simplicity of elctric, so it gets my vote
Spaceclam 07-10-2004 10:08 AM
the thing that shoos me away from electric is how much it begins to cost when you get into larger planes. it costs a lot more than gas and gas has that cook ticking idle sound. a brushless motor (you cant go brushed with a larger 3d plane) will cost upwards of $300, and another $100 for a controller and another $100 per pack and while that eventually pays for itself in savings over gas, it still does not have that cool ticking sound.;)
Ian.W 07-10-2004 10:21 AM
listen to this then, for a 2 meter 3D aerobat
in the UK a YS 160 dingo with hyde ARI mount and propper hatori header and pipe about 600 GBP
in the UK an electric setup:
Macker C50 Xl with 6.6:1 (there abouts) Gearbox and a 90A ESC, 2x 5s2p lipos (wired for 10s2p (5000mah all up, 14c discharge)), prop, ESC, mount, top of the range shultze charger and a programmer for ESC about 900GBP
YS 30% fuel about 30 GBP a gallon, youd use this in about 2 weeks, so, it would take 10 weeks to pay off the electric setup. even tho the Lipos go off at about 200 cycles that way over a years of flying, then it would be 400GBP to replace them, then it would be payed off in about 15 weeks of flying
thats y i like leccy so much. with the new brushless and lipos i dont think IC will last too much longer, giveit 5-10 or so years an it will be very much a minority
Henke Torphammar 07-10-2004 11:22 AM
then if you had too chose between a gasser foamie or a scale/profile electric for the rest of time?!
I have to agree with Spaceclam a well tuned YS runs close to an electric setup! amazing throttle charasteristics, and never a deadstick!
lord lucan 07-10-2004 11:32 AM
ORIGINAL: edible_engine
...with the new brushless and lipos i dont think IC will last too much longer.
...Explain this in a bit more detail will you EE....while you'r putting your tin hat on :)
