GP Ultimate 3D!!
1 Attachment(s)
Hey everyone,
I wanted to share this plane I built with my fellow enthusiast. I took this 40 size GP Ultimate kit and modified it a little. Here is a run down of what I did: -- Added two bays (approx 6") to each wing tip. -- Using Dual aileron servos mounted on the bottom of the lower wing. -- Using dual elevator servos mounted on the fuse side at the rear of the fuse. -- Using pull/pull rudder set up. -- Using a OS 91fs. -- Using dubro fiberglass landing gear (added after pics taken) -- Using a 16 oz tank mounted in the fuse at the CG. -- Using a horizontal stab from a 3d giles. -- Increased the aileron size by 25% Finish weight is just a hair over 7lbs. It flies like a dream... It will knife edge all day. It will hover and torque roll well. It will also flat spin very well. It floats well too, but will tip stall if I push it. So what do you think? |
| All times are GMT -8. The time now is 07:33 AM. |
