G-Trick 90 CG? Throws?
I have a Kyosho G-Trick 90 that is ready for balancing and radio set-up. I was not able to get the manual with this model, so I was looking for some insight. With a little math and some throw eyeballing....I know it will be setup fine for initial flights.
I would hate to waste my time on the conservative side.....and just start with Naruke's recomended CG and throws. I have the Giles, and the airplane is flawless with the aft recomended CG location. Thanks for your time guys. George |
RE: G-Trick 90 CG? Throws?
CG - 165mm from LE. Manual does not specify, but I assume it means at the fuse side.
Elevator throw - 14mm low rate/40mm high rate each side of center. Measured at the inboard tip of the elevator counterbalance. Aileron throw - 16mm low rate/23mm high rate each side of center. Measured at the inboard tip of the aileron TE. Rudder - 40mm low rate/60mm high rate each side of center. Measured at the forward tip of the rudder counter-balance. Richard |
Thank you very much. I am new to this site, and its great to have info like this.
GR |
If you want, the manual is available on-line from Kyosho's Japanese website (don't worry, it has English in it also):
http://www.kyosho.co.jp/web/download..._trick90_m.pdf |
I've flown this beauty for a while now. crashed 3 gtricks, the first being the original kyosho thing n the rest including the 4th one i'm flying, all being custom made with a lighter wing loading. Its a precise, maneouverable and aesthetically designed machine. btw, what engine r u planning on using? whats ur all-up weight?
as far as the throws are concerned, make sure u dont hv any gaps in the hingeline, otherwise a higher throw angle will be required. otherwise, stick with the manual instructed throws. In case of further questions regarding the aircraft , u can email me at [email protected] or PM me. |
The plane has a ys 91 w/hatori exhaust components.
No gaps. Hingeline is snug, and sealed. Will either fly it this afternoon or Friday. I will post an after flight D-Brief!..LOL thanks fellas GR |
| All times are GMT -8. The time now is 11:35 PM. |
