Modeltech Magic assembly question
It turns out the magic uses two different pushrod connectors. A normal one, 2-56, for the ailerons and a smaller one for the pull-pull setup. I wasn't paying that close of attention and used the smaller connectors on the ailerons and now I'm afraid they are stretched and won't hold properly on the thin threads. Any idea what size these are and where I can buy new ones. Other ideas? Thanks
RE: Modeltech Magic assembly question
grip them togeter and squeeze tightly it may bend them so they fit
One of mine was broke. I could not find a replacement - like you said they are small - so I soldered on a 2-56 adaptor so I could use a more standard connector. The other is to use cables.
Use Cables! it's works too much better!
yes pull pull the stock clevises strip out thats bad
| All times are GMT -8. The time now is 09:43 PM. |
