RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Quickest spooling props? (https://www.rcuniverse.com/forum/3d-flying-82/217332-quickest-spooling-props.html)
earl williams 08-03-2002 11:48 PM
On 2 strokes there seems to be an issue of them spooling back up to power slower than 4 strokes from a hovering attitude. Which props tend to spool up faster: low pitch or high, wide blade or narrow, lighter or heavier?
vinnie 08-04-2002 02:16 AM
Low, narrow, lighter. Low pitch, WIDE blade, lightweight props usually yield satisfactory results. :)
Geistware 08-04-2002 02:51 AM
Narrow blade scimitar wood or carbon fiber propellers.
Mejzlik or Menz
Yellow Jacket 08-04-2002 12:25 PM
Get wood over CF
OUTCAST 08-04-2002 09:09 PM
The lighter the prop the better, the lower the pitch the faster the spool but not necessarily the better performance [assuming your comparing it to another of the same diameter from the same manufacture]. Narrow blades in my experience do tend to spool faster and also have higher static RPM then there counter part, and strangely sometimes actually have more static thrust, although I have no explanation for this.
