RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Li-poly regulator 6V (https://www.rcuniverse.com/forum/3d-flying-82/2229075-li-poly-regulator-6v.html)
drumbum 10-05-2004 05:15 PM
I am building 28% edge. I havent done large gas since 1993. I would like to use a Thunder Power 2s1p 7.4v 2100maH regulated down to 6v for my servos where can i find souch a regulator. also can you run your RX on 6v or does it have to be individually regulated down to 4v?
Rhilluk 10-05-2004 06:05 PM
RE: Li-poly regulator 6V
rx can be run on 6v but they were designed for 4.8v, you could get a opto isolator and reg from central hobbies, they do that sort of thing. But running it om 6v should be ok.
DMcQuinn 10-05-2004 08:24 PM
And you can order the 6.0 V regulator from batteriesamerica.com. $20 I think
drumbum 10-05-2004 09:06 PM
thanks
