RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Chip Hyde's Vision 3D (https://www.rcuniverse.com/forum/3d-flying-82/2229108-chip-hydes-vision-3d.html)
Scott Dilley 11-21-2004 02:56 PM
RE: Chip Hyde's Vision 3D
Maudib, If you really want to, come down this week and we can fly. I have not flown the DV, but the other fellow that flew mine said that it is a better all-around plane than the DV. Send me an email if you want to try to make a trip: [email protected]
Maudib 11-21-2004 04:07 PM
An 11 hour drive one way is just a tad long... especially with the Holidays here...
I suppose I'll tough it out and fly on those rare decent days through the winter.
Lord willin', I'd like to do a road trip one day... see America and flyin as many different states as money allows... :) Wouldn't that be a hoot?
From 3D flying in Arizona with the guys at DA to sloping the coastal cliffs of California...
It would be nice to get a large travel trailer and haul myself around. :)
Thanks tho for such a warm and heartfelt invitation...
-David
Scott Dilley 11-21-2004 06:36 PM
You know... the travel trailers that the motocross dirt bikers use have a cargo section in the back. Would make a perfect airplane hauler/living quarters. Ahhhh
Daryl g lane 11-23-2004 07:19 PM
Is there anyone flying one yet,and if so how about a flight report. Thanks Daryl
Maudib 11-23-2004 07:20 PM
I thought you were???? How 'bout a video?
Daryl g lane 11-23-2004 07:28 PM
I have flown mine for 3 days with about nine flights.I was just seeing if anyone with one had had a flight report and maybe what is being tried.
Scott Dilley 11-23-2004 07:31 PM
I have 4 flights on mine. A little coupling during knife edge, no bad habits that I have found.
Daryl g lane 11-23-2004 07:53 PM
Tried a 23/8 bolly prop and it seems to fly better than the carbon ones I tried. This plane will hover at 1/4 throttle
NE0 11-29-2004 07:14 PM
There seems to be some discrepency regarding the standoffs for the DA50 on the Vision. The original manual said to use 2.5" standoffs, and the new "revised" manual says to use 1/25" standoffs. Problem is, with the shorter standoffs, that pushes the cowl back into the gear and you have to cut out a lot of cowl. Also, this would move your balance back a good bit.
Can anyone flying the Vision explain what standoffs you used, what you did about the cowl, how it balanced... battery & servo position, etc..
Also interested in your opinions on using the CA hinges as supplied?
Daryl, you say you've been flying yours and love it... how bout some info?
Thx,
Tom
Scott Dilley 11-29-2004 08:44 PM
I used the standoffs that Came with the DA 50. They worked well, only cutting out a small notch for the gear. I changed the hinges to B & B Giant scale hinges. They seem stronger.
Maudib 11-29-2004 09:12 PM
Where did you balance it at? Where did you have to place the battery to do so? Pull-pull rudder or servo in the tail? In quiring minds want to know... :)
BTW... Ijust got some 5995TG servos in.... ZERO lash in the geartrain... simply awesome. 333 oz. in torque
Scott Dilley 11-29-2004 09:29 PM
It is balanced behind the tube, and going back. The rudder is pull-pull. It flies well, although the Cg is coming back about another inch or so before it is all said and done.
bahamadude 11-29-2004 09:35 PM
Can anyone post a video of the vision please ?
I am considering the vision or the yak 87 from extremeflight rc
What do you all think ?
Maudib 11-29-2004 09:46 PM
You can't go wrong with either plane... the upside to the Vision is that it is in stock now. But the Yak's are purported to be around the bend...
There are 2 videos of Chip flying the Vision on his website:
http://www.chiphyde.com/html/vision/visionvideos.html
What impressed me with these videos is the wind was howling, but the plane doesn't seem to show much adverse reaction... not getting bumped around and tracking true... Of course the low speed harriers (upright and inverted) and the harrier circles are something too...
These two planes will be neck and neck for top 50cc Monoplane ARF of 2005...
Eric.Henderson 12-01-2004 08:56 PM
1 Attachment(s)
It was raining hard today so I went to the work shop to align my DA-50 on the Vision. I'm using the Slimline muffler so I wanted to mount the engine inverted. I had noted that Chip has the engine canted to the side for the header etc.
I lined the cowl up with the fuselage and then decided to make up a tool to find the center of the thrust line on the fire wall. It made it real easy to mark the firewall and then extrapolate the stand-off holes. Then the rain stopped (VBG)
I think the pictures describe it best.
Regards,
Eric.
pinto 12-04-2004 02:40 AM
1 Attachment(s)
I had a chance to fly mine today, and I love it, I installed the engine with the suplied 2 1/2 inch stand offs and it flies fine, I am using hitec 5645 on everything, except rudder, on the rudder I am using a jr 8611, no cables, I balanced it with a jr 3000 mah battery behind the tube, against the radio tray, I think after the engine gets broken in I'll move the battery back maybe about an inch or more. For power, DA 50 with tunned pipe, awesome!!
R/C Foolish 12-04-2004 03:36 AM
Finished mine tonight, hopefully will get it in the air tomorrow. DA-50 mounted on supplied standoffs. Using Duralites for batteries balanced at back of wing tube. Using Futaba digitals all around, I decided to go with the dual aileron set up. Maybe overkill in the wings but this is one big plane compared to my GP PW. Anybody have any tips for the first flights?
R/C Foolish :D
Maudib 12-04-2004 09:19 AM
Yep...
Relax... this plane willl make the Patty feel like a Roseanne. :)
Seriously tho, I'm betting this plane will feel like it's 1/2 the weight of the Patty in the air, float in on landing.
You should have plenty of time for recoveries and little tendency to snap.
Speaking of snap... you guys with the warm air and green grass...
Whose done some walls? Both upright and inverted entering? How about elevators?
Eric.Henderson 12-11-2004 11:06 AM
ORIGINAL: Maudib
Alright guys... you've been asking... I just got the video for the Vision 3D ARF uploaded to Chip's site....
This looks like every bit the awesome plane the Double Vision... I hope to have mine soon too, but my season is on it's last legs, so I won't get mine in the air til next year... :(
You can see the videos on Chip's site or click the following link to go direct to the Vision videos page:
[link=http://www.chiphyde.com/html/vision/visionvideos.html]Chip Hyde Vision 3D ARF Videos[/link]
Enjoy!
Tried the video and got " The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Is there a new page please?
Eric.
Maudib 12-11-2004 11:55 AM
I just went there fromt eh reply you sent me... works fine...
Here is the direct link... sometimes RCU's forum software messes up the links...
Eric.Henderson 12-11-2004 05:53 PM
Great and thank you. It is working for me now.
Merry Xmas...
E.
JBrannon 12-13-2004 03:02 PM
The fusalage looks exactly like the DV, I wonder if the Visions wings would fit on the DV. 2 planes for the price of 1.5.
Joe
Eric.Henderson 12-13-2004 05:07 PM
that's a nice thought.
It's close but not really the same. The bottom, bi-plane, wing would be the equivalent to the Vision wing and is in the wrong place. I think that you would have to move the tube etc.
Bashedit 12-15-2004 09:51 PM
Since the snow has started flying up, and the Vision was on the building board, I started to read your threads on the Vision. I decided to use a little different approach to the stand-offs. After reading that Chip now goes along with the shorter stand-offs, but only having the standard ones, I decided the easiest thing to do was cut 2" off the front of the fuse. It was then pretty simple to stand the fuse up on end and trace a new firewall out on a piece of aircraft ply. When I cut the old parts out I weighed them, minus 5 oz, add for the new firewall and triangle stock, 3 oz, Hmm, just saved 2 oz!!
While it was opened up I also thought about the tank location. I don't know about you guys but I don't like the CG moving around on me as I go from full tank to near empty. So I took the fuel tank mounting plate marked the location of the center of the tank and fit it in under the wing tube by cutting out the formers there. I realize this would create a problem if your running a pipe and need the hollowed out area, but I'm using a Slimline Pitts that I've had on the DA.
I've taken some pictures and I'll post them if anybodies interested.
Maudib 12-15-2004 10:27 PM
Tank location... yep... you can cut the cross piece from the bottom of one former and install the tank under the tube...
You can also install it above the tube and cut the former out of the hatch (and move it forward to maintain strength) so if you use the pipe you can still center the tank on CG.
Cut 2" off the plane eh? True to your RCU handle... ;) Well as they say... uh.... "Good luck with that." :)
