RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Engine for Madness (https://www.rcuniverse.com/forum/3d-flying-82/2340692-engine-madness.html)
Trailing Edge 11-13-2004 06:55 AM
Engine for Madness
Hi, I've just bought a madness and I'm not sure which engine to put in it. I want to put one of my current engines in there. The options are :
OS70FS
OS46FX (With Genesis pipe)
OS90FS
Has anyone got any suggestions as to which is the best to use and why?
Cheers:eek:
novabill 11-13-2004 08:57 AM
RE: Engine for Madness
What's a maddness? Got a link to it?
YNOT 11-13-2004 10:29 AM
Orignial Madness made by ZN Line, great bird.
Designed for the YS45 or a YS 63.
Flew mine on a YS45. It hovered it and had power to pull out, however it was lacking in power. I put a OS 50 on it later in life and it performed better.
Go with the 70 and a 13-4W APC and see how it does. Not sure you would be happy with the 46 even with the pipe.
If you are unhappy with the knife edge and/or the roll rate, remove the wing tips.
NZ Scythe 11-13-2004 08:41 PM
I'd suggest going with the OS70
I have a Madness 2 with a YS 63 and it has awsome power, The 46 wouldn't be enough power. I rekon the 90 would probably be too heavy...
Good luck
Is it the Original Madness or Madness 2?
fredo 11-14-2004 05:59 AM
a friend of mine has Saito 72 in it and it seems plenty of power. This plane is very light and doesn't need any more than that.
