RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   3D Move Help Needed !!!!!!!!! (https://www.rcuniverse.com/forum/3d-flying-82/2347023-3d-move-help-needed.html)
DragonHeart 11-15-2004 04:37 PM
Hi Guys,
Hope someone can give me an insight or help learning this Manoeuver i want to try to pull off a Hover and go into a Torque Roll with my Funtana.......... the Hovers not a problem i can do that...... but i just cant seem to torque roll i kinda loose it easily............ what am i doing wrong.......... i really like this move as it looks impressive but i just cant pull it off.... the planes a Funtana 40 with a Jen 53 Upfront........ which gives it plenty of power to hover so im not sure thats the problem............ i have a Saito 100FS soo not sure if that would be better....... but i think its more i need to learn how................. do i need to programme anything or setup anything on my radio to perform this move ? i have a Futaba 9C
Any advice or help would be great...... :D
JohnVH 11-15-2004 04:41 PM
RE: 3D Move Help Needed !!!!!!!!!
Try to get the plane perfectly vertical, and do not climb. what is the problem you are having?
DKjens 11-15-2004 04:50 PM
Practice, practice, practice, take a break, practice, practice, practice, take a break, practice, practice, etc., etc., etc.
DKjens
Shahid 11-15-2004 04:53 PM
Heres one tip, with the belly towards you move the rudder stick towards the falling wing.
Luke 3D returns 11-15-2004 05:07 PM
yep and get it LOW. Its a lot easier to see what the plane is doing and react to it when its lower to the ground.
Shahid 11-15-2004 05:21 PM
Thats true, when its far away you dont see the small movements and suddently its all over.
AeroDave 11-15-2004 05:38 PM
A sim can really help you get going with this one. You can practice the belly in orientation over and over, without woorying about anyone else watching, hogging the freq, etc. Even when you begin to think you have it down, its a good idea to practice this move for a few minutes each day, until it is second nature.
YNOT 11-15-2004 06:18 PM
It just looks soooooo simple, huh?
DKjens nailed the solution.
Welcome to the addiction:D
