RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   PLEASE post some Pull-Pull Elevator Pics (https://www.rcuniverse.com/forum/3d-flying-82/239437-please-post-some-pull-pull-elevator-pics.html)
Mike Rojas 08-22-2002 02:15 AM
Could someone please post some pics of Elevator pull-pull set up,the elevator connection and the servo connections,PLEASE!I want to do this on my Creek Katana and am not sure how.I've done lots of rudders but never Elevator.Thanks,
Mike
mecam 08-22-2002 04:17 AM
http://www.********.net/pages/pugsley/dpedge3.jpg
http://www.********.net/pages/pugsley/dpedge5.jpg
http://www.********.net/pages/pugsley/dpedge6.jpg
http://www.********.net/pages/pugsley/dpedge7.jpg
TailTouch 08-22-2002 12:12 PM
Pull Pull Elevator
Thank you mecam.
I was planning this setup for the AW Edge 60/90.
Some questions though...
1) Are the 2 servos for each elevator half or can you use one servo for both elevators ?
2) Can you lay the servo on it's side coz unless the servo sits dead center, one wire will be longer than the other one.
Thanks.
Billy Hell 08-22-2002 01:46 PM
Knife PP
1 Attachment(s)
ll
Billy Hell 08-22-2002 01:48 PM
2
1 Attachment(s)
2
3
1 Attachment(s)
3
mecam 08-22-2002 02:01 PM
Re: Pull Pull Elevator
Originally posted by jatt5abdaa
Thank you mecam.
Thanks.
1) You can use either 1 or 2 servos. Get the highest torque if you are only using one.
2) Servo does not have to be dead center. You adjust the wire length accordingly. Also servo does not have to be on it's sides. I would use some kind of antenna tube at the exit hole of the fuselage to make the wire run smooth.
Mike Rojas 08-23-2002 01:14 AM
Mecam,thanks for the pics,excellent.Is that DP Edge available yet?If not,when?
Mike
Nex 08-23-2002 03:13 AM
Cool topic. Im glad I get to see how you guys do the pull-pull thing.
Im building my third plane, a .46 size Giles 202 ( http://www.greatplanes.com/airplanes/gpma0238.html ), and Im wondering how to set this up. The kit comes with instructions for using the standard metal control rod for the rudder and the same type of control rods for each elevator half. I was hoping for something more glamorous and a little lighter (i.e. pull-pull cables for the rudder and maybe the elevator, too.)
What kind of things does this require? I've seen how the servos attach to the cables and what not, but are there any special tools/techniques required? Is there a need for running conduit for the metal wire? Just how much stress can those little wires handle?
I've also heard of 4-40 systems and ??? 6-56 ??? systems or something like that. What is the difference between the two? (I don't really know what Im talking about on this one :) )
I understand the basics to how the rudder system works, but I don't fully understand how to use this method on a 2-piece elevator. Can you attach the cables running from both halves to the same servo? If so, is this wise/optimal?
I know I just spewed a bunch of questions :) and any help would be greatly appreciated.
mecam 08-23-2002 10:35 PM
A 2-56 pull-pull system would be fine for your .46. You use the 4-40 on 1/4 scale planes.
Depending on your servo direction, you put both top elevator half cable on one side of the servo and both bottom elevator half cable on the other side. I would use the Sullivan Pull Pull systems because they come with threaded clevises and it would be easier to adjust the tension of the cables. Also their cables are coated with silicon so if they rub on each other it won't generate interference.
Hope that helps.
mecam 08-23-2002 10:38 PM
Mike
I called DP and they said that Edge will be out in a month. And we all know that's more like 3 months.... I was going to buy this plane and put a ZDZ 50 on it, but Aeroworks is coming out with their 31% Arf at about the same time frame so I think I would go with the bigger plane instead.
Crash90 09-10-2003 08:49 PM
RE: PLEASE post some Pull-Pull Elevator Pics
I cant access the pics of your pull pull elev setup. Could you PLEASE repost or email them to me?
Bill Mixon 09-10-2003 09:02 PM
RE: Pull Pull Elevator
jatt5abdaa,
You can use one servo for both elevator halves, I have done this on a few planes.
For it to work properly the servo MUST lay on it's side, and the servo arm needs to be centered in the fuselage.
Even if the servo (mounted upright) were centered in the fuse you could not get it to work properly. There would be a lot of slack in the cables when the elevators were deflected.
You also need to have the control horn/hinge alignment as close as possible.
Bill
Crash90 09-10-2003 09:25 PM
I am confused as to why the servos must be mounted in the center of the fuse? Center meaning from left to right? Or centered vertically?
When mounting servos for pull pull elev. is it critical that the center of the servo be level with the horizontal stab?
The reason I ask is because the stab is mounted quite high on the fuse. To keep the servos centered vertically with the stab they would have to be installed in the cockpit.
Bill Mixon 09-10-2003 10:10 PM
Yes, both side to side and vertically.
It's hard for me to explain here in this thread, but if you do some geometry, and trigonometry you can see how things get out of whack the further you move away from (center center).
Will it be a big problem? probably not. You can get away with it being off a fair bit in both directions and it still work Ok.
Technically if the servo had to be mounted way below (or above) the same plane as the stab, your servo arm needs to be perpendicular to an imaginary line between the servo output gear and the hinge line. In other words the servo arm would or should not be straight up and down. However for that to work out properly the control horns would have to be set at the same angle, not 90 degrees to the control surface. Not very practical given the horns available.
Believe it or not, the only way to setup pull pull "perfect" is to have the same center to center distance on both the servo arm and the control horn with the servo 90 degrees to the control surface (side to side and up and down)
Many people believe that you can use like a 3" servo arm to a 2" control horn setup, and the linkage still work out right. It will not..
It won't be off much, but do the math and you will see.[sm=wink.gif]
Regards,
Bill
