RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Prop for 3D? (https://www.rcuniverse.com/forum/3d-flying-82/2430701-prop-3d.html)
FlyguyXII 12-13-2004 08:01 PM
Prop for 3D?
Hi guys just thought i would get your sugestion on a prop.
I have a goldberg sukhoi arf with a saito 1.80 on it im thinking a 18x6 prop would be good on it but am not sure if that is to much prop for the 1.80. If i do go with the 18x6 im going to go with a Mezlick prop. Also what would be a good break in prop for the engine. from what im reading in the manual they dont have a recomended break in prop so im selecting the one that was recomended the most which is a 16x8. I have heard that you need to go up one size if you go with a mejzlick prop is this true? sorry for the questions just want to get it right for my first four stroke. Thanks
Dewey2 12-14-2004 02:11 PM
RE: Prop for 3D?
i didn't vote because the apc 18/6 wide blade isn't there its the 3d prop most thrust which is what you want for 3d use a 16/8 two blade for break in
WingShot 12-14-2004 05:03 PM
RE: Prop for 3D?
What's the best 3d prop for a Saito 1.50?
Dewey2 12-14-2004 05:45 PM
RE: Prop for 3D?
ORIGINAL: WingShot
what rpm do you get with the prop you use now what size prop is it would you use 30% heli fuel all the time
FlyguyXII 12-14-2004 09:24 PM
RE: Prop for 3D?
Sorry the APC 18x6 thats in the poll is the wide blade
Dewey2 12-14-2004 10:43 PM
RE: Prop for 3D?
definitely the apc 18/6 wide blade
meeko 12-15-2004 07:11 AM
RE: Prop for 3D?
APC 18x6w....
and if you can put it os160fx on 10lb plane :D
FlyguyXII 12-15-2004 08:23 PM
RE: Prop for 3D?
What is the difference between the apc wide and the mejzlik 18x6 besides weight? I would think that the mejzlik would have better throttle response because its a lighter prop?
EXTRA ADDICT 12-15-2004 09:02 PM
RE: Prop for 3D?
I am going to try an apc 17x4w on my goldberg sukhoi arf but im running a saito 150. It flew great with an apc 16x6 but I think the engine needed just a little more prop.
