flaps/spoiler setup on 23% edge?
how should i set up the flaps on my egde for 3D? is it ailerons go up when elevator goes up or ailerons go down when elevator goes up? i always thought it was the second one i mentioned becuase it would give a tight loop radius. should i have both of these programmed into my radio, one for hovering and the other for tumbles?
RE: flaps/spoiler setup on 23% edge?
I have spoileron mix "elevator goes up, ailerons go up" bound to one of my switches. I think mine is setup with about 30%. It helps wing rock a little and I use it while doing elevators, harriers and walls.
| All times are GMT -8. The time now is 02:20 AM. |
