Tuned pipe on 3D plane or not?
Hello everyone,
I and another flying guy are wondering if a tuned pipe would make 3D'ing better. It should provide more power (wich seems nice for 3D), but they say a tuned pipe will peak the top RPM only.. So if anyone has done the test, please let us know. This problem keeps some off our club awake for some nights. Thank you in advance for the answer See you, Jean-Luc |
RE: Tuned pipe on 3D plane or not?
I read in another thread that a Macs header and tuned pipe (not the tuned system) worked well. He tuned it for max RPMs and then backed the pipe up until he lost about 500 RPMs. He said that adding that little extra length really broadened up the midrange and helped with throttle response wich are two things you deffinately need for 3D.
So, go get some sleep now:D |
Yes, if you leave a tuned pipe untuned (ie too long) you wont get the big boost in top end power though you will still get quite a bit, but it wont go "on the pipe" which means you get far better throttling.
Whats this I hear about people piping 4 strokes? I don't get it at all. The pipe would do nothing because the motor has an INTAKE stroke, and the exhaust valve would be closed when the pulse hit the engine.
Anybody? |
ORIGINAL: codiddley Whats this I hear about people piping 4 strokes? I don't get it at all. The pipe would do nothing because the motor has an INTAKE stroke, and the exhaust valve would be closed when the pulse hit the engine. Anybody? Why do you think people put Flo-Master exhausts on their cars? I know they sound cool, but they also aid in scavenging. All engines perform the same task weather 2c or 4c, they are air pumps. They both have exhaust pulses as well (the two stroke has twice as many though for a given RPM) By tuning the length and diameter of the exhaust system, you can adjust the torque curve on a 4c the same way as you would on a 2c. I think most of the 4c tuned systems are designed to extract extra RPMs though as these engines come out of the box set up with mufflers designed to produce the power in the low and mid range. I don't think the benefits of a 4c tuned system would as great as with a 2c system though because the cam profile has so much to do with where the powerband of the engine is. |
| All times are GMT -8. The time now is 03:47 AM. |
