RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   What exponentials do you usually use on big Extras? (https://www.rcuniverse.com/forum/3d-flying-82/2718038-what-exponentials-do-you-usually-use-big-extras.html)
JuanSG 03-02-2005 10:38 AM
Hello!
I'm in the process of programing my TX for my CAmodel Extra 300L 31% (2360mm), and I would like to know what exponentials and dual rates you usually use for IMAC and 3d, what flights modes, etc.
Juan Sánchez
flyboy91 03-06-2005 12:17 AM
RE: What exponentials do you usually use on big Extras?
Juan,
I usually for imac use dual rates with elevator at 15 degrees low rates with 30% pos expo(JR 10x) for high rates about 25 degrees and 45% expo. I only use this dual rate for spins. On the ailerons I use about 20 degrees low rate with 40% expo and 38 degrees high rate and 60% expo. This is only used for snaps. Rudder is what ever percent to hold knife edge at 1/2 deflection rudder. with about 40% expo and high rates as much as you can get with 65% expo.
for 3d flying. I use a flight mode that consists of my normal imac set up for smooth maneuvers, one that has all the throw I can get, Then I have another 2 that are the same as listed just with smoke.
