RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Propeller Size Question (https://www.rcuniverse.com/forum/3d-flying-82/2755650-propeller-size-question.html)
Wolfpack 03-11-2005 11:58 PM
I am building a omp 65" yak 54 3d profile and putting the ys110 on it. What size apc prop would you use?
This is my first 3d plane, and quite frankly I know nothing about props and 3d. I fly quite a bit and have an extra with a ys 110, but I understand that is completely different flying.
JoeAirPort 03-12-2005 12:17 AM
RE: Propeller Size Question
16-6 or 17-6 seems to be a good choice for 3D. Like Dave shadel says in the second link below, keep the engine in the 9000-9500 RPM range. The 16-6 might transition a little faster which is what you want for 3D, but watch that peak RPM. Throttle management might be needed if it goes near 10,000 on the 16-6.
http://www.rcuniverse.com/forum/m_23...tm.htm#2394156
http://www.rcuniverse.com/forum/m_18...tm.htm#1896208
http://www.rcuniverse.com/forum/m_18...tm.htm#1875425
Wolfpack 03-12-2005 12:54 AM
Awesome, exactly what I was looking for, thanks a lot !!!
