Quiqes TOC model
1 Attachment(s)
Hello Mommy!
Quiqes TOC model
1 Attachment(s)
I have got to get sponsered.
Quiqes TOC model
1 Attachment(s)
Quiqes TOC model
1 Attachment(s)
Quiqes TOC model
QUIQUE AND HIS NEW TOC MODEL, THE YAK 54¨
Wingspan 120 inches Wing area 2,800 square inches Weight 40 LBS Fuselage balsa/playwood/carbon Wing Balsa/spruce/foam ribs Radio JR 10X Servos DS8411 x 17 Engine 3W 150 QS Regards |
Quiqes TOC model
OK.. Where do I put my name on the list? I want one.. hehe.
-Doug Cronkhite -Team JR |
Quiqes TOC model
Where are all those servos??
Quiqes TOC model
I think in the plane :)
Quiqes TOC model
My guess would be as follows:
3 per aileron 2 per elevator 6 on rudder (it's huge) 1 on throttle Doug Cronkhite Team JR |
Quiqes TOC model
Thats what I was thinking...must be fun ganging 6 8411's..
Quiqes TOC model
Not to sound like a blatant plug.. hehe.. but it's pretty easily done with a pair of matchboxes.
Quiqes TOC model
Any more info on this bird? Is it a kit, who built it, flying characteristics? It appears to have cannister mufflers, because of the exit position of the exhaust. Also, 40 lbs is quite a bit heavier than Quique's previous TOC planes. Wonder how this will affect those vertical multiple snap maneuvers that are so prevalent in TOC sequences, especially with an airframe that appears to be so fat and "draggy". I'm sure it must fly great though if Quique is giving up the Extra to fly the Yak.
Quiqes TOC model
Quique's Yak does have 17 servos.
4 per aileron (8 total) 2 per elevator (4 total) 4 on the rudder 1 throttle The ailerons are HUGE, like all of the other control surfaces on this plane. He was experimenting with spades like on full scale planes, but the last time I saw it, they were off (Do you call them spades Doug? I have heard people call them shovels.). It has to be seen in real life to be enjoyed to the fullest. He has so much stuff on this airplane that he only wanted 1 reciever. He has like 4 batteries, 4 regulators, 4 matchboxs, the 17 servos, and all that is routed to the rx. He said it is the best plane, hands down that he has flown. |
Quiqes TOC model
Can you get more detailed pics perhaps?
Quiqes TOC model
Originally posted by Acroman330 Quique's Yak does have 17 servos. 4 per aileron (8 total) 2 per elevator (4 total) 4 on the rudder 1 throttle The ailerons are HUGE, like all of the other control surfaces on this plane. He was experimenting with spades like on full scale planes, but the last time I saw it, they were off (Do you call them spades Doug? I have heard people call them shovels.). It has to be seen in real life to be enjoyed to the fullest. He has so much stuff on this airplane that he only wanted 1 reciever. He has like 4 batteries, 4 regulators, 4 matchboxs, the 17 servos, and all that is routed to the rx. He said it is the best plane, hands down that he has flown. 40 pounds isn't really all that heavy actually. Most of the '36 pound' TOC airplanes are turning out to be more like 39 - 42 pounds when you put them on a good scale. Hehe. Also.. at 2800 square inches of wing area.. the loading is very light and the airplane should be very nice to fly. Doug |
Quiqes TOC model
It looks like the wing was lowered, isn't the Yak54 a mid wing plane?
Quiqes TOC model
1 Attachment(s)
Here is a real Yak-54 for comparison. I think Quique's interpretation looks better. :D
| All times are GMT -8. The time now is 10:20 AM. |
