RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Harrier 3D hatch vibration (https://www.rcuniverse.com/forum/3d-flying-82/2874307-harrier-3d-hatch-vibration.html)
lennyk 04-13-2005 08:05 PM
How are you guys holding down the front of the Harrier's hatch where it goes in the slot ?
It is a bit loose and vibrates a lot.
L
EXTRA ADDICT 04-13-2005 08:11 PM
RE: Harrier 3D hatch vibration
I put thin foam weather stripping under the edges of mine it helped alot.
Bodge 04-15-2005 05:24 AM
Run some cyano over the bit that goes into the slot and let it dry. Repeat if still loose. I packed the tank in foam and left some of the packing above the fuselage sides. Pressing the canopy down on this stopped any movement.
