RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   u can do, with 120 gms?? (https://www.rcuniverse.com/forum/3d-flying-82/301365-u-can-do-120-gms.html)
arniebarn 10-05-2002 02:00 AM
i have not seen on the u can do post that any one has tryed a 120 2cy .. as i have two 120 webras and a 120 gms i am wondering if this motor will work in the u can do,..
mecam 10-05-2002 02:45 AM
It will work but will be nose heavy. This plane flies better with the CG 2" behind the recommended.
knife edge jim 10-05-2002 08:30 PM
I put saito 1.20 on mine then put the battery under the stab. It only took 1 ounce of tailweight to balance at 5 1\2 inchs. I also put the throttle servo behind the wing. Flys awesome!!!
arniebarn 10-08-2002 05:51 AM
thanks for the reply ill try my webra,thanks.
