RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   U-Can D0 engine (https://www.rcuniverse.com/forum/3d-flying-82/3125524-u-can-d0-engine.html)
TSuppa 06-30-2005 03:04 PM
U-Can D0 engine
OK I purchased a U-Can-Do .46 with the intention of putting my saito .91 in it. In the mean time I sent this engine to Horizon for a check out. It needs @ $234.00 worth of repairs. So I will probably look for a different engine. What is the best 4stroke and 2 stroke for this plane?
rclement 06-30-2005 03:07 PM
RE: U-Can D0 engine
Tsuppa, I have a Saito 82 in mine and it works perfect. Nice hovering, nice pullout. Really good power to weight ratio.....[8D]
TSuppa 06-30-2005 03:34 PM
RE: U-Can D0 engine
anyone tried a ST .91
fasterthanlife 06-30-2005 04:08 PM
RE: U-Can D0 engine
Saito 100 hands down
STG 06-30-2005 04:16 PM
RE: U-Can D0 engine
SA100 or 91FX 2 stroke
thedak 06-30-2005 04:43 PM
RE: U-Can D0 engine
saito 82
gjeffers 06-30-2005 05:44 PM
RE: U-Can D0 engine
1 Attachment(s)
saito 100
EL TEMUCANO 06-30-2005 08:26 PM
RE: U-Can D0 engine
OS .46 AX , 12/4 APC , AAA PACK BATERIES , AND MICRO SERVO FOR THROTTEL = VERY LOW WING LOADING FOR 3D :D
SERGIO
GRANT ED 07-01-2005 04:30 AM
RE: U-Can D0 engine
I had an OS 91 in mine. If I were to do it again I would probably get a Saito 82. IMO the 91 was just a waste of excess power.
rclement 07-01-2005 10:42 AM
RE: U-Can D0 engine
I agree Grant Ed, although that 100 the Gjeffers has in his....... Now that's class..... And he flies the thing about 3 feet above the deck inverted......[>:][>:][>:]
Liberator 07-01-2005 07:20 PM
RE: U-Can D0 engine
I have the Magnum .91 in mine and it's a great combo, probably some over kill there, but more is better than less.
Just as an FYI, found the motor on e-bay and it was NIB for $150.00. I have heard some folks say bad things about the Magnum, but I am pretty impressed with it, it's been a great motor.
Tom
mikeboyd 07-06-2005 03:58 PM
RE: U-Can D0 engine
Once again, keep it light. Many are using the new Hype OS .50 on 30% Nitro and a 12X4 prop. I have a Magnum .52 on one now, running on 15% Nitro and a 12.25X3.75 APC prop and no limit on vertical and hover less than 3/4 throttle. I had tried a .91 mag 4 stroke, but the extra wing loading with that big engine hurt the 3D stuff more than you would imagine. My choice would be the .91 Saito, because it is about 4 oz. less than the competition and will swing a 15X4 APC wide blade pretty well.
Hope you enjoy yours as much as I have enjoyed mine. Just a really fun, relaxing, forgiving airplane, when you get it set up right.
TSuppa 07-06-2005 05:28 PM
RE: U-Can D0 engine
I have a ST .91 2 stroke. Do you think this will work?
rclement 07-06-2005 07:31 PM
RE: U-Can D0 engine
TSuppa, I just guessing but I would think that a 2 stroke that size might tend to fly that plane too fast. Maybe if you propped it right it might not. Mostly the larger 4 strokes seem to work the best. 82 - 100
