RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   3D Prop (https://www.rcuniverse.com/forum/3d-flying-82/3137861-3d-prop.html)
CJKling 07-05-2005 11:45 AM
3D Prop
Guys...
What prop would you put on an O.S. .46 AX running on a Goldberg Ex-Treme 330 s profile fun-fly plane for 3D type flight??
Thanks for any suggestions
JoeAirPort 07-05-2005 12:33 PM
RE: 3D Prop
APC 12.25x3.75 or 12x4. That engine loves bigger diameter props from a review I read a few months back. Just make sure it's broken in before loading the engine with the bigger props.
CJKling 07-05-2005 01:28 PM
RE: 3D Prop
Thanks joe, I figured it would be something in that range
JoeAirPort 07-05-2005 04:54 PM
RE: 3D Prop
If those props turn too slow or spool up too slow, try an APC 11x5 or 11.5x4. Keep the diameter as big as possible while still getting a good transition on the engine. Someone recommended a Zinger 11x4 or 11x5 on another thread and that's a good choice too. The wood props are WAY lighter and spool up much quicker from my experience.
delman 07-05-2005 08:47 PM
RE: 3D Prop
you might try an apc 12x4 and a zinger 12x4 - see which you like better
sport10 07-05-2005 09:36 PM
RE: 3D Prop
I really like the 12x4 APC on my .46 BB engines for 3D. It has thrust similar to the 12.25x3.75 with better throttle response.
