RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Phoenix 7 (https://www.rcuniverse.com/forum/3d-flying-82/3226-phoenix-7-a.html)
FHHuber 06-03-2002 07:34 AM
A Vintage Pattern Ship!!!
Measure 25% back from the LE at the root and at the tip. Connect those points and measure halfway out on each wing. connect those two points. That line is your 25% MAC line.
A 25% MAC CG will fly and be safe with just about anything except a flying wing. You can always move the CG back if the plane needs it due to sluggish performance or poor knife-edge flight.
Its awfully hard to move the CG back after take-off when its too far aft. A plane with too far forward CG flys hot and sluggish (high stall speed and poor elevator response) A plane with CG too far aft flies once and becomes toothpicks. (sometimes they do a loop on lift-off... straight into the ground before you can respond...)
Hossfly 06-15-2002 09:22 PM
Phoenix 7
Pick up your RCM, check address for Don Lowe and contact him. He was designer.
