What prop if not APC
Right now I'm using APC wide blade props for 3D flying. I think they are pretty heavy. So I'm looking for some light alternatives. One is a 12,25x3,75 and the other is a 14x4W. What other props can provide the same great thrust like APC but at less weight?
RE: What prop if not APC
I used a Pro Zinger 14x4 with good results.
i use pro zinger also, i change back and forth to change cg with apc, on my cheap scale there is about an ounce difference on the 15x6;)
The weight of the APC prop is not an issue --
TheAPC is one of the least expensive props which hold shape while revvingup down pick the right blade size and the engine will rev quickly Just because a prop is light -doesn't make it a good 3 D prop. There is a new clone of the Mejzlic now available in Czech Republic -extremely light - if tthat really is what you feel necessary I think it is MZ anyway two letters. extremely light -look exactly like Mejzlic |
i like menzs
Mejliks are now been regarded as "not so good for 3D" and more of a IMAC prop |
Mejzlik 3D's Great for me.
I have dreamed about a 12.25x3.75 cloned in CF
| All times are GMT -8. The time now is 01:00 PM. |
