Showtime &YS110
Just putting a show time together,and using a ys110.The manual states to maintain 5&3/4 inches from the firewall to the fromt face of the thrust washer.In doing this I feel there isn;t enough of the mount extending past the front of the engine.Has anybody run into this situation in using the 110 engine.and has anybody shimmed out the mount,It would only take about 1/8 of an inch.Thank you for your help.
RE: Showtime &YS110
with the 110 the mount tips. should be exactly even with the "ears" on the motor"the flat mount part with the holes"will give you the proper cowl clearance
| All times are GMT -8. The time now is 08:02 PM. |
