RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   CG Matrix, a tip-stalling machine??? Help. (https://www.rcuniverse.com/forum/3d-flying-82/3316761-cg-matrix-tip-stalling-machine-help.html)
rightflyer 09-17-2005 06:29 PM
RE: CG Matrix, a tip-stalling machine??? Help.
I am putting my Matrix together with a saito 82, but am concerned about posts regarding the airleron servo mounts. Should I open up my cover to CA the blocks down? Thanks
BlackB12 09-19-2005 09:10 AM
ORIGINAL: rightflyer
I don't think you'll need to remove any covering. Just flow some thin CA in there before you mount the servos. I fluttered and stripped both aileron servos yet the mounts remained rock solid on mine.
MIke
rightflyer 09-19-2005 04:34 PM
Thanks for the tip!
rightflyer 09-24-2005 02:22 PM
I am installing my Saito 82 on Matrix. I was how other installed their throttle on the 4-stroke? Did you use a bellcrank?
BlackB12 09-24-2005 02:51 PM
I installed my throttle just like it showed in the manual. I notched out a bit of the one bulkhead, then epoxied the plastic throttle pushrod sleeve to it. My YS is mounted inverted so it was a straight shot along the side of the fuselage to the throttle arm on the carb.
Mike
rightflyer 09-25-2005 05:29 PM
I was ready check my CG and the manual says start at 5 1/2". However, they did not say 5 1/2" from where? Since this is not a straight leading edge wing I am not sure of the actual balance point. Since it is a low winger, I would assume you would also balance inverted.
jbogdano 09-25-2005 06:04 PM
Rightflyer,
I've got my Matrix balanced at around 6 1/2" from the leading edge AT THE FUSELAGE and it seems to fly great. Try to move it there and see how it does. Good luck with this plane. I know that setup may have been difficult but once you nail it in it really flys great. I'm very happy with mine.
Jeff
rightflyer 09-25-2005 06:18 PM
BlackB12 09-25-2005 07:23 PM
I just got done flying after moving the CG back to 6" and what a difference it made. Much more tumbly now and boy does it ever nail inverted flat spins! I'm going to fly it like this then move it back to 6.5" if I can.
Mike
rightflyer 10-01-2005 03:22 PM
I am trying to set up my Matrix with a Saito 82 and not use the stock tank. However, I am having a problem finding a tank that fits so that can be at the right level for fuel feed. I was wondering what type and size of tanks others used,
AHPowelson 10-02-2005 12:20 AM
I'm using a Sullivan "Nev-R-Leak" 10oz round tank. I had to open up the former a little bit to get it to fit.
rightflyer 10-02-2005 07:47 AM
Thanks for the tip!
