Will it fly ok?
Ok I glued the wing to the fuse on my 47" OMP edge and I got it all centered from tip to tip but forgot about from the table to the wing. So when you look at the plane from the front the left wing is acute to the fuse and the right side of course is obtuse. Its not really as bad you think but I think its some were around 5degrees off center. Do you think it will fly ok? I don't want to put everything in it and find out that it doesn't fly for crap. I need answers fast!
RE: Will it fly ok?
You'd better cut it and do it right
RE: Will it fly ok?
Dudes its epoxied, and it would take FOREVER to cut it
RE: Will it fly ok?
I just took a measurement and at the wing tips to the ground its about 1 1/2" off
RE: Will it fly ok?
Fly it
RE: Will it fly ok?
to late, i already cut the fuse around the epoxy and now i'm waiting for the new epoxy to dry.
| All times are GMT -8. The time now is 10:02 AM. |
